| Stupid Q http://auszookers.com/forum/viewtopic.php?f=5&t=6363 |
Page 1 of 2 |
| Author: | Dee [ Tue Sep 01, 2009 2:08 pm ] |
| Post subject: | Stupid Q |
Do i need to remove transfer to pull gearbox? (new clutch time) |
| Author: | tanshi [ Tue Sep 01, 2009 2:10 pm ] |
| Post subject: | Re: Stupid Q |
nah just pull the jack shaft. |
| Author: | BlueSuzy [ Tue Sep 01, 2009 2:12 pm ] |
its on the edge of slightly too heavy with 1 person.. |
| Author: | shep [ Tue Sep 01, 2009 2:16 pm ] |
BlueSuzy wrote: its on the edge of slightly too heavy with 1 person..
are you gay? i have no collar bones and i can still remove/replace a sierra trans case on my own. |
| Author: | Damo [ Tue Sep 01, 2009 2:18 pm ] |
It's a little awkward but even I can lift it by myself I usually pull the front driveshaft as well as the jackshaft, as it gives you more room to maneuver the box out. Pull the gear lever before you start too. If you still have the stock exhaust there is a bracket on the top of the cat. converter which can be a pain to get off, but if you undo that and disconnect the exhaust at the manifold flange that will give you more room to move too. A 2" bodylift makes it a million times easier in my experience. |
| Author: | Scrawny [ Tue Sep 01, 2009 3:34 pm ] |
And don't forget the wiring on the firewall!! It's a pain to do while balancing the box on your head |
| Author: | Damo [ Tue Sep 01, 2009 3:37 pm ] |
ScrawnC wrote: And don't forget the wiring on the firewall!! It's a pain to do while balancing the box on your head
Good tip! Also, I usually drain the box before I pull it out, but you could probably use one of those plugs to stop the oil coming out the back of the box. In any case you need to address that if you don't want to be covered in gear oil!!! |
| Author: | BlueSuzy [ Tue Sep 01, 2009 3:51 pm ] |
shep wrote: BlueSuzy wrote: its on the edge of slightly too heavy with 1 person.. are you gay? i have no collar bones and i can still remove/replace a sierra trans case on my own. Are you gay? Cos u must be reading in the closet? He said he is removing the gearbox not transfer!
And are you swapping the box while the car is on the ground? no jacks etc? Sorta an awkward position.. |
| Author: | shep [ Tue Sep 01, 2009 4:25 pm ] |
that was just a slip up, i meant the g/box. what is so hard about it, i doubt that it weighs 30kg. it is a tight fit but that is it. |
| Author: | BlueSuzy [ Tue Sep 01, 2009 4:34 pm ] |
Maybe im just weak.. I havent done it for bout 2 yrs.. I was younger then.. Now im lifting heavy stuff everyday so it prob be easier. Yes i am weak, but not gay.. Not that there is anything wrong with that.. I am married to a malteser with bootay |
| Author: | Hybrid [ Tue Sep 01, 2009 5:38 pm ] |
Sorry bluesuzy but I've got to agree on the gay call. Now for the tech. Try cutting a small v slot in the front of your rear gearbox mount. There is like web on the back of the gearbox that is a pain in the arse if you don't cut the v in. |
| Author: | shep [ Tue Sep 01, 2009 5:43 pm ] |
BlueSuzy wrote: Maybe im just weak.. I havent done it for bout 2 yrs.. I was younger then.. Now im lifting heavy stuff everyday so it prob be easier.
Yes i am weak, but not gay.. Not that there is anything wrong with that.. I am married to a malteser with bootay fess up time.. i did fuck up and read it as trans case ball had to help me get the bastard back in |
| Author: | Damo [ Tue Sep 01, 2009 6:02 pm ] |
Hybrid wrote: Sorry bluesuzy but I've got to agree on the gay call.
Now for the tech. Try cutting a small v slot in the front of your rear gearbox mount. There is like web on the back of the gearbox that is a pain in the arse if you don't cut the v in. Hey a V is a good idea. I just took about 10mm off the front of the bracket. |
| Author: | BlueSuzy [ Tue Sep 01, 2009 6:09 pm ] |
shep wrote: BlueSuzy wrote: Maybe im just weak.. I havent done it for bout 2 yrs.. I was younger then.. Now im lifting heavy stuff everyday so it prob be easier. Yes i am weak, but not gay.. Not that there is anything wrong with that.. I am married to a malteser with bootay fess up time.. i did fuck up and read it as trans case ball had to help me get the bastard back in Buhahahaha silly Shep. Its ok to admit stuff. Hey i admited im weak first but everyone wants to be tough guys here so them them talk their dick size up too. We are human after all. |
| Author: | joeblow [ Tue Sep 01, 2009 6:34 pm ] |
haha....funny stuff..... sierras are a piece of piss. i'm used to lifting vit boxes in all the time. and i have never had to cut anything from the g/box mount. and sorry BlueSuzy...........................i am hung |
| Author: | shep [ Tue Sep 01, 2009 7:41 pm ] |
joeblow wrote: haha....funny stuff.....
sierras are a piece of piss. i'm used to lifting vit boxes in all the time. and i have never had to cut anything from the g/box mount. and sorry BlueSuzy...........................i am hung like an ant fixed. |
| Author: | Hybrid [ Tue Sep 01, 2009 8:04 pm ] |
sierras are a piece of piss. i'm used to lifting vit boxes in all the time. and i have never had to cut anything from the g/box mount. You don't have to cut anything off Joe. It just makes it easier and I'm all about working smarter not harder........ P.S Blue my dick is massive.........ly dissapointing |
| Author: | BlueSuzy [ Wed Sep 02, 2009 3:29 am ] |
Buhahaha
| Author: | Dee [ Wed Oct 21, 2009 8:30 pm ] |
I cannot figure out whats holding the gearbox in. I've taken off/undone everything. I can only get it to slide along the studs about 1/4" away from the engine, and then it something hits and i cant get it out. The only thing i can think of is the starter motor, but i can't see it hitting anything?? |
| Author: | steak_knife [ Wed Oct 21, 2009 9:47 pm ] |
Did you take the gear stick out?? |
| Author: | Dee [ Thu Oct 22, 2009 9:05 pm ] |
haha. yes. |
| Author: | 31zook [ Thu Oct 22, 2009 9:17 pm ] |
Hybrid wrote: ...I suggest you pull yours out while taping it just so we can get some respect back for you...
what are you talking about? |
| Author: | SuziBlu [ Thu Oct 22, 2009 10:49 pm ] |
BlueSuzy wrote: shep wrote: BlueSuzy wrote: Maybe im just weak.. I havent done it for bout 2 yrs.. I was younger then.. Now im lifting heavy stuff everyday so it prob be easier. Yes i am weak, but not gay.. Not that there is anything wrong with that.. I am married to a malteser with bootay fess up time.. i did fuck up and read it as trans case ball had to help me get the bastard back in Buhahahaha silly Shep. Its ok to admit stuff. Hey i admited im weak first but everyone wants to be tough guys here so them them talk their dick size up too. We are human after all. An you called me a big girls blouse coz I admitted defeat, lol, shame. |
| Author: | losfer [ Thu Oct 22, 2009 11:17 pm ] |
got the cover with the 2 10mm bolts off the bottom of the gearbox ? |
| Author: | BlueSuzy [ Sat Oct 24, 2009 12:02 pm ] |
SuziBlu wrote: BlueSuzy wrote: shep wrote: BlueSuzy wrote: Maybe im just weak.. I havent done it for bout 2 yrs.. I was younger then.. Now im lifting heavy stuff everyday so it prob be easier. Yes i am weak, but not gay.. Not that there is anything wrong with that.. I am married to a malteser with bootay fess up time.. i did fuck up and read it as trans case ball had to help me get the bastard back in Buhahahaha silly Shep. Its ok to admit stuff. Hey i admited im weak first but everyone wants to be tough guys here so them them talk their dick size up too. We are human after all. An you called me a big girls blouse coz I admitted defeat, lol, shame. Buhahahaha, now you know i was joking |
| Author: | Dee [ Thu Oct 29, 2009 5:44 pm ] |
turns out i had to pull the starter off. thanks anyway. Also had to pull the front drive shaft as bellhousing got stuck between it and the exhaust. On a side note, having my jackshaft out, i just noticed that the input flange on the transfer has a bit of play... how much is normal? I can twist it about 3-4mm (along the circumference of the flange) before it 'takes up'. Also, with the case in 4 and the front drive shaft disco'd, i noticed theres alot of play in the rear diff (backlash). I can twist the drive shaft back and foward somewhere between 1/8th and a 1/4 of a turn (1/6th?)... again whats normal here? would appreciate if someone could check on their car? |
| Author: | Ridge [ Thu Oct 29, 2009 6:36 pm ] |
locker in the rear? sounds similar to mine |
| Author: | Dee [ Thu Oct 29, 2009 6:44 pm ] |
Ridge wrote: locker in the rear? sounds similar to mine
yep lockright/auto. its only been like it since i put the locker in so i thought it might be because of that. |
| Author: | v.w.dave [ Thu Oct 29, 2009 6:45 pm ] |
I had mine out 3 weeks ago and I got help with stabbing it back in but that is just becasue I like my back. But I could have done it myself. Now that was in a shop on a 2 post not on the ground. And to add to that I didnt have to cut anything. |
| Author: | 2dogs [ Fri Oct 30, 2009 3:59 am ] |
if you are doing it on the ground with no jacks etc. make sure the dowels (little cylinders) stay in the engine not the gearbox... hard lesson learnt yesterday. there is not much clearance but with a little effort (about 8hrs if like me you had no idea) and a bit of brute force it should come out. it"s not that heavy either, i'd say 25kg. |
