| Low Level Coolant Indicator/Alarm http://auszookers.com/forum/viewtopic.php?f=5&t=6369 |
| Author: | Rusho [ Tue Sep 01, 2009 10:52 pm ] |
| Post subject: | Low Level Coolant Indicator/Alarm |
Hi All, Just wondering if anyone uses a low level coolant indicator/alarm. I don't want a repeat performance of blown heater hose turning into blown head gasket. I have beenlooking at the following www.enginesaver.com.au About $190 for an inline version into the radiator hose. It's kinda hard for a temperature gauge to register with no water in the cooling system Thanks Rusho |
| Author: | eldo [ Tue Sep 01, 2009 11:36 pm ] |
| Post subject: | Re: Low Level Coolant Indicator/Alarm |
i reckon they are great idea, however a little expensive |
| Author: | shep [ Tue Sep 01, 2009 11:44 pm ] |
Rusho81 wrote: Hi All,
Just wondering if anyone uses a low level coolant indicator/alarm. I don't want a repeat performance of blown heater hose turning into blown head gasket. I have beenlooking at the following www.enginesaver.com.au About $190 for an inline version into the radiator hose. It's kinda hard for a temperature gauge to register with no water in the cooling system Thanks Rusho that is how you know that you have an issue. |
| Author: | royce [ Wed Sep 02, 2009 12:24 am ] |
seen a type somewhere that measure actual cylinder head temp that cheaper than that |
| Author: | Rusho [ Wed Sep 02, 2009 12:37 am ] |
i suppose you don't remember where royce??? |
| Author: | hutch [ Wed Sep 02, 2009 12:38 am ] |
I use one in my diesel patrol... a VDO one. I would never have a diesel motor without fitting one. It came on once and scared the sh** outa me. Pulled over, shut the motor down, popped the bonnet to investigate, and thankfully it was only the wire on the sensor had fallen off. |
| Author: | Rusho [ Wed Sep 02, 2009 12:41 am ] |
I realise that shep, just want more of an early detection thing, all the water went in a blink of an eye, the temp gauge didn't even move from it's normal position |
| Author: | daaskapital [ Wed Sep 02, 2009 3:14 am ] |
Totally recommend them. I use a similar device which has saved two engines now - had a diahatsu applause that blew a hose when driving & also a 4 runner that had a split hose losing all the coolant over night - jumped in the car to go to work the next day & when turned the ignition the alarm went off - immediately checked radiator to find no water. Would have totally cooked her forsure without the alarm. The one i`ve used is actually soldered into the top of the radiator by natrad radiator specialist with a dash mounted sensor & alarm. $190 is far cheaper than a rebuild IMO. |
| Author: | Damo [ Wed Sep 02, 2009 11:37 am ] |
royce wrote: seen a type somewhere that measure actual cylinder head temp that cheaper than that
Agreed, but the buzzer and/or light would be a handy addition. Anyone with some electronics knowledge should be able to put together something like this too. |
| Author: | Hybrid [ Wed Sep 02, 2009 12:10 pm ] |
I wonder if Jaycar has got a kit. |
| Author: | royce [ Wed Sep 02, 2009 2:42 pm ] |
jaycar do a low coolant kit, which is all this is, IMHO much better to have a system that says HEY NUMNUTS YOU HEAD IS TOO DAMN HOT you can still have coolant and it overheats withough relising |
| Author: | weaves [ Wed Sep 02, 2009 5:19 pm ] |
I remember reading a write up in 4wd monthly, they put one in a red jimny and did it all with parts from jaycar/dicksmith and the cost was way less than $190. one thing they said to do was to mount it low enough that you don't set it off every time you go on a angle as it could become annoying. i think i read it at the hospital so don't think i even have the issue, but if come across it i'll post up the details behind it. or someone else may have it kicking around at home. weaves |
| Author: | Rusho [ Thu Sep 03, 2009 11:57 pm ] |
Sorted. $104 + $15 from the radiator shop to make a braise up a copper pipe for the sensor and flare the ends to inline the sensor in the top hose. http://www.ashdowningram.com.au/CA2571B ... %9Dtarget= Will post pics after install |
| Author: | daaskapital [ Fri Sep 04, 2009 2:10 am ] |
Rusho81 wrote: Sorted. $104 + $15 from the radiator shop to make a braise up a copper pipe for the sensor and flare the ends to inline the sensor in the top hose.
http://www.ashdowningram.com.au/CA2571B ... %9Dtarget= Will post pics after install Thats kit is the one i`ve been using too mate - cheap insurance |
| Author: | TheOtherLeft [ Tue Nov 15, 2011 2:11 am ] |
Very much a gravedig, but what would be more useful, a low coolant alarm (engine saver) or a temp alarm, either mounted on the block or thermostat? |
| Author: | royce [ Tue Nov 15, 2011 3:00 am ] |
low coolant might not overheat, full coolant can still overheat, I would (and have) pick head temp any day |
| Author: | Rusho [ Tue Nov 15, 2011 3:38 am ] |
Doesn't the head need to be tapped for a particular fitting?? |
| Author: | royce [ Tue Nov 15, 2011 3:48 am ] |
Rusho wrote: Doesn't the head need to be tapped for a particular fitting??
I have one on the mini that is a thermocouple washer that goes under a head bolt |
| Author: | TheOtherLeft [ Tue Nov 15, 2011 3:51 am ] |
I've also read that mounting the sensor on the thermostat is a good position. Which would be more accurate - thermostat or engine block? If the engine block is there any position in particular - front, rear of block? |
| Author: | royce [ Tue Nov 15, 2011 3:53 am ] |
on the head, its more sensitive to damage from heat, back might be less swayed by air cooling it but tis something you probabyl have to monitor for a while to get a feel for whats normal and whats not |
