It is currently Fri Oct 02, 2026 10:14 pm
Post Posted: Mon Sep 07, 2009 6:38 pm
im only getting 220ks out of a tank of my coily 30ltre tank just had a service before i bought it any idea's anyone before i take it to the expensive mechanics up here cheers
Post Posted: Mon Sep 07, 2009 6:43 pm
what size tyres do you have?
$70 an hour is quite cheap.
Post Posted: Mon Sep 07, 2009 6:54 pm
stock as a rock it is mate. well they charge a fortune been in a mining town
Post Posted: Mon Sep 07, 2009 7:04 pm
$70 an hour is nearly half what a workshop charges here. :wink:
check air filter isn't blocked and that the choke is turning off.
Post Posted: Mon Sep 07, 2009 7:18 pm
70 is what the mechanic is getting...
cheers bloke ill check that out
Vehicle: SJ80
Post Posted: Thu Sep 10, 2009 6:40 am
Just need to check basic stuff... Good plugs and leads - at $70 p/h you can afford to replace these yourself, whether it needs it or not.
As already mentioned, get it hot, whip the air inlet to the top of the carb off, and make sure the autochoke is coming off.
While you are there check/replace the air filter.
Post Posted: Thu Sep 10, 2009 10:53 am
without putting it on a dyno and gas anyliser all you can really do is check for any external fuel leaks, check that the auto choke is completly off and adjust the carby mixture by 'feel', in other words screw the mixture screw all the way in till you notice it starts to idle a bit shit, then back it back out about 1/2 a turn.
Users browsing this forum: Google [Bot] and 182 guests
