I dunno much about carbs so you will have to go easy on me.
The carb was empty, inline filter was empty too so put a bit of juice in the tank then got the girl to turn the key while i sprayed a bit of start ya bastrd down its throat, after a bit we could start it without the spray but it wouldnt idle. (bearing in mind there is no choke cable) after fiddling with the choke i could get it to rev up and slow right down, shut it off and left it for a while and tried it again now all it does whenever i turn the key is it goes off its tits and playing with the choke does nothing. what did i do? and what can i do to fix it?
Users browsing this forum: No registered users and 221 guests
