It is currently Sun Nov 15, 2026 10:14 am
Post Posted: Fri Jan 19, 2007 8:46 pm
Got some rear springs kicking around and was thinking about putting them under the front of the zook.
I was going to do a chassis extension, but have read about people putting them on with just 2" shackles. This would probably give more droop too, so could be a good thing.
What's the best way to go?
Post Posted: Fri Jan 19, 2007 9:22 pm
I did it years ago with a longer shackle and redrilling the fixed mount so the diff stayed more or less where it used to be, might not of been as good as it could but worked well enough for me
casper has the rear mounts of an LJ on his, they are offset a bit so like a chassis extension but stock looking
I think a combination of the 2 would allow a stock shackle and good flex without it looking too nasty
Post Posted: Sat Jan 20, 2007 2:45 am
Any pics of this anywhere? I dunno what a LJ mount looks like.
Post Posted: Sat Jan 20, 2007 2:59 am
http://www.auszookers.com/uploads/forum ... resize.jpg
Post Posted: Sat Jan 20, 2007 3:03 am
Bruce wrote:
http://www.auszookers.com/uploads/forums/2006_1125ruf0006resize.jpg
Cheers Bruce! I don't believe all those things they say about you :lol:
Post Posted: Sat Jan 20, 2007 2:44 pm
:roll: It's all Royce and Steve's doings :windowface:
Post Posted: Sun Jan 21, 2007 5:21 am
I've moved my bumper in closer to the body so I think if I move the shackle hangers forward it's going to look out of place.
I'm thinking of doing what you mentioned Royce, redrilling the spring mount hole back a little, and using a slightly longer shackle. Then to move the axle forward a little will drill a new hole on the perch and spring plate.
Should work the same and improve the approach angle slightly. More importantly it will look more stock.
Post Posted: Mon Jan 22, 2007 1:44 am
take lots of pictures... will be very helpful :D
thats how im hoping to do mine as i don't want a big shackle extension. i want it to look as stock as it can
Users browsing this forum: Google Adsense [Bot] and 62 guests
