| tires and rims http://auszookers.com/forum/viewtopic.php?f=5&t=6531 |
| Author: | nick.gooding [ Wed Sep 09, 2009 1:48 am ] |
| Post subject: | tires and rims |
was just wondering whats the largest size tire i can fit on a standard rim. looking at 30x9.5x15 i dont htink they will fit. just dont no if ill have money for rims thanks |
| Author: | Scrawny [ Wed Sep 09, 2009 1:56 am ] |
| Post subject: | Re: tires and rims |
30's wil fit but not ideal. I've even seen a 31 fitted to a standard rim |
| Author: | nick.gooding [ Wed Sep 09, 2009 1:58 am ] |
OK that would be good, the tires i wont are 30x9.5x15 so if i can get them on it would save me some hassle for a while until i can get rims maybe a month or 2 later. |
| Author: | S13RR4 [ Wed Sep 09, 2009 2:01 am ] |
my mate runs some 30x9.5's on his stock rims they fit fine they just don't get pushed out as much as if they were on wider rims if you know what i mean but they'll still work- would probably just have to watch pressure to make sure they wear evenly |
| Author: | Gwagensteve [ Wed Sep 09, 2009 2:20 am ] |
a 30 isn't anywhere near the largest tyre you can run on a stock suzuki rim. 34 9.5 15 Swamper will go on a standard sierra rim. A 9/34 16 Swamper will go on a 16" sierra/LJ rim A Q 78 swamper will go on a 16X7" XL-7 or GV rim. That's 35.5 tall. a 9.00 16 will go on a 7 rim easy, that's 36" tall. Pretty sure you could run a 38X11 16 bogger on a GV rim too. However, these are all cross ply tyres so aren't as rim width sensitive A 30 X 9,5 isn't ideal on a sierra rim, but it's OK short term. It will likely crown a bit and the handling on road won't be as good as it could be. You will also have tyre clearance problems on the shock mount/inner guards unless you are WT. Steve. |
| Author: | nick.gooding [ Wed Sep 09, 2009 12:00 pm ] |
Gwagensteve wrote: a 30 isn't anywhere near the largest tyre you can run on a stock suzuki rim.
34 9.5 15 Swamper will go on a standard sierra rim. A 9/34 16 Swamper will go on a 16" sierra/LJ rim A Q 78 swamper will go on a 16X7" XL-7 or GV rim. That's 35.5 tall. a 9.00 16 will go on a 7 rim easy, that's 36" tall. Pretty sure you could run a 38X11 16 bogger on a GV rim too. However, these are all cross ply tyres so aren't as rim width sensitive A 30 X 9,5 isn't ideal on a sierra rim, but it's OK short term. It will likely crown a bit and the handling on road won't be as good as it could be. You will also have tyre clearance problems on the shock mount/inner guards unless you are WT. Steve. ok thanks steve bid help i wont have them on there for too long. |
