It is currently Tue Oct 06, 2026 8:22 am
Post Posted: Wed Sep 09, 2009 11:29 am
Hi I have a carby 16v 1600 out of a swift and was looking at putting a center point injector off a falcon as well as a turbo.
I know it has been done but cant find any info on appropriate ecu and any pick up points needed or wiring diagrams. I have heard that a mazda ecu can be used but not sure which model. Hopefully someone can shed some light on the topic?
Post Posted: Wed Sep 09, 2009 12:36 pm
If you're turboing you're probably best off going for an ECU that you can change the fuelling maps on, so you can get the AFR correct across the rev/load range. I know there was a guy on the Sunshine Coast that did a Mazda ECU on a zook engine but i'm not sure how you would go about changing the fuelling with an ECU like that. I have a feeling that it would be a bit of a hit and miss affair, with more misses than hits :lol:
There are more and more 2nd hand programmable ECUs around these days which makes it a less expensive proposition.
Post Posted: Wed Sep 09, 2009 1:54 pm
It was Rhett in Gympie off Outers that fitted a Mazda 121 TBI setup.
He runs it as a blow through setup and has not modded the ECU at all.
He uses a turbo off a Pajero diesel.
Post Posted: Wed Sep 09, 2009 9:07 pm
I was looking at doing the same sort of blow through set up. A pajero is a 2.8 turbo diesel 4cyl. The turbo I have is off a 2.8 turbo rodeo so it should have similar effect
