It is currently Wed Oct 07, 2026 8:33 am
Post Posted: Fri Sep 11, 2009 5:15 pm
I posted this on outers but thought i'd put it up here to make sure i get the full range of expertise.
Ok i know a couple of guys use the 4 speed auto aw4 box. What i would like to know is.
1. how do you go with the auto off-road seeing as it isnt really gear selectable i.e always starts in 1st low. If you have low range crawler gears does this cause any issues when you would normally select to start off in a higher gear in a manual.
2. I have heard there are some people who are using a simple switching setup to change gears in these things using power to the solinoids.
What i would like to bring up is the possibility of setting up a sportshift style config. Where it drives normal on road like a normal auto. Flick a switch on the dash and beable to use the shifter to "select gears"
thoughts?
Post Posted: Fri Sep 11, 2009 5:21 pm
this is what i want to do with mine, there was a site 'aw shifting' that offered a control box to allow this type of setup, but the guy has stopped making them.. there are a few vids on u tube of vehicles running his system, just search for aw shifting.
ive found another guy doing a similar setup, but havent really had the time to look into it, try here http://radesignsproducts.com/default.aspx
Go Hard, Trailer Home
Post Posted: Fri Sep 11, 2009 5:35 pm
That looks really quite simple. Might be challenging getting to stop acting getting it to switch between modes is all
Post Posted: Fri Sep 11, 2009 5:38 pm
It's a bit of a trek for you but MV auto's does some cool shit with the late model jap import stuff. just google MV automatics & it comes up in heaps of forum discussions & is well known in the Drag racing scene. A few mates have had him build auto's up & they are awesome, one of the most impressive was a 3.0l TD auto pootrol that he built up & kitted
M V Automatics
1 Stirling Rd, Blackwood, SA 5051
p: (08) 83700430
Post Posted: Fri Sep 11, 2009 5:42 pm
mine has that. when i'm offroad and i want to start in low gear i put it in 'L'. when i want to go a lttle faster i put it in '2', and when i want to go faster again i put it in 'D', its work the other way also :wink:
if you ever plan on engineering the vehicle down the track, and the electronic auto is not wired up as per factory you may find it will not pass.
Post Posted: Fri Sep 11, 2009 5:47 pm
any chance of a write up Joe? Im happy to do this after it is regoed and im sure i could make it "unplugable"
Post Posted: Fri Sep 11, 2009 6:00 pm
Good info on the site Polar_Bear posted up http://radesignsproducts.com/aboutus.aspx
Post Posted: Fri Sep 11, 2009 6:07 pm
Actually yeah i missed that
Durr
So i guess you would switch the main power off to the TCU
and then use manual switching. once you were done you would power the tcu back on.
Post Posted: Fri Sep 11, 2009 6:49 pm
as a side note.
This is the info on the aw4 from the FSM
And this is the info on the Jimny Auto from the FSM
Any one know or would hazzard a guess if you can do the manual shifting on a jimny box?
Post Posted: Fri Sep 11, 2009 9:27 pm
Just out of interest.you want to convert it to full manual?
Post Posted: Fri Sep 11, 2009 9:30 pm
no
I want to be able to select the gear it starts off in.
I will be hopfully running duel transfers and if i am climbing hills etc i wont nessessarily want the low low low gearing of first gear
Post Posted: Fri Sep 11, 2009 10:01 pm
I don't want to derail your thread Tanshi but this info should at least allow people that want to run one of these tranmissions but dont want to use the factory ECU. Eg, putting one on the back of a carby engine. Shouldn't it?
Twitchy should be along shortly i'm sure :lol:
Vehicle: 1999 Jimny
Post Posted: Fri Sep 11, 2009 10:42 pm
already got my eye on it....lol
Post Posted: Sat Sep 12, 2009 10:19 pm
yeah that should allow you do run an auto with out a TCU.
mightmouse from outers does the very thing.
Im going through the jimny FSM to try and figure out if you can do this with them too.
Post Posted: Sun Sep 13, 2009 11:44 am
I can't see why not. What engine are you putting the Jimny box behind BTW?
Post Posted: Sun Sep 13, 2009 12:36 pm
At the moment i have itbehind a baleno 1.6 but if i can get this vit 4 speed in, i wanna see if i can get it to work behind a standard 1.3 or similar
Post Posted: Sun Sep 13, 2009 12:53 pm
You've got me all interested now, so i'll have to see if the 4 speed that I have stashed away is still there. It shouldn't be too hard to get it mated up to a GTi block.
Post Posted: Sun Sep 13, 2009 1:50 pm
Well i have had a look at the wiring diagrams, and it should be pretty easy to set up the manual shifting on the jimny box to make it work with the carby motors using the orginal position switch
Vehicle: '92 Sierra
Post Posted: Sun Sep 13, 2009 4:59 pm
Does the AW4 have a lock up torque converter. Could probably control it with the megasquirt if your putting it back in damo.
Post Posted: Sun Sep 13, 2009 5:22 pm
yeah it does have a lock up torque converter
Post Posted: Sun Sep 13, 2009 5:32 pm
Yeah i've just been looking at that this morning, will keep it in mind as the GPIO/MegaShift project moves forward. It can be done currently using a stand alone MS2 though.
Vehicle: '92 Sierra
Post Posted: Sun Sep 13, 2009 9:23 pm
I would have thought with the MSNS Extra there would be enough customisable outputs to control the auto.
Post Posted: Sun Sep 13, 2009 9:30 pm
I though so too, but it seems there's a bit more to controlling an auto than I thought originally. I'm a bit ignorant when in comes to slushboxes :?
Post Posted: Mon Sep 14, 2009 2:51 pm
There must be a few peeps around with these boxes in Vits? Can any one get me a length from the bellhousing face to the rear output ? just need this to figure out if i can fit one
Post Posted: Mon Sep 14, 2009 11:03 pm
ive got one in my garage, i'll go measure it
Users browsing this forum: Google [Bot] and 209 guests
