It is currently Wed Oct 07, 2026 12:25 pm
Vehicle: 75 Cruiser
Post Posted: Sat Jun 13, 2009 12:15 pm
Can anyone add any info to this, like what horsepower each one as? or add another motor type with specs that could be considered for a engine swap? I wouldn't have a clue of what half of these engines are even :oops:
A12 87 kg 192 lbs
A14 93 kg 205 lbs
L18 118 kg 260 lbs
CA18ET 118 kg 260 lbs
QR25DE 121 kg 267 lbs
CA18DET 128 kg 282 lbs
SR20DE 139 kg 306 lbs
SR20DET 149 kg 328 lbs
FJ20ET 166 kg 366 lbs (205 hp)
KA24DE 167 kg 368 lbs (est)
J20A (weight? Hp?)
H20A (weight? Hp?)
With Transmission:
SR20DET 490 lbs
RB25DET 667 lbs (280 hp)
VG30DET 589 lbs
Ford Small Block V-8 487 lbs
Chevy Small Block V-8 575 lbs
Suzuki Sierra: G13BA 73kg
Suzuki Vitara: G16B 89kg
Post Posted: Sat Jun 13, 2009 12:28 pm
4AGE 155kg as fitted to car less exhaust manifold has 8-100-123kw depending on spec
Vehicle: jimny
Post Posted: Sat Jun 13, 2009 12:44 pm
A12 is 69 horsepower, go the datto
Post Posted: Sat Jun 13, 2009 4:11 pm
im pretty sure the j20a is about 97 kw and fairly big torque too??sorry if im wrong
EDIT
some overseas forum just had 107 kw at 6000rpm and 193 nM torque at 4000 rpm
Post Posted: Sat Jun 13, 2009 9:24 pm
G13B is 49.5kw
Post Posted: Sun Jun 14, 2009 8:02 pm
A12GX = 83hp
A14GX = 102hp
But this is where the real stuff happens....
LJ50 2stroke 539cc = 66kg / 33hp @5500rpm (yep that's a whopping 24kw)
41.6lb-ft torgue at 3500rpm
Post Posted: Sun Jun 14, 2009 8:17 pm
whats the stock power of a G16 (carbed version) 8v
Post Posted: Sun Jun 14, 2009 11:18 pm
The ca18de has 105kw at the flywheel standed
Sr20de has around the same
The Ca18 works great in the zook and i have an sr20de in my dato 1200 the runs a 14.6 at the drags
Trent
Drive it like u stole it!!!
Vehicle: '92 Sierra
Post Posted: Mon Jun 15, 2009 1:25 pm
G16a carb'd is listed at 55kw Jamie
Post Posted: Mon Sep 14, 2009 2:44 am
G16A 8 valve TBI is 59kw.
Users browsing this forum: No registered users and 151 guests
