It is currently Fri Oct 02, 2026 4:14 pm
Vehicle: 1993 Sierra 1.6 efi Vit motor,
Post Posted: Tue Sep 15, 2009 12:11 pm
Anyone had experience with a porous vitara block,
The previous owner of the motor put liquid metal around the area. It has started to slowly leak and I have put a product similar to Bars Leaks in it. The leak has stopped somewhat but not completely.
I have heard some people get these Tig welded but I am told this is not successful.
Post Posted: Tue Sep 15, 2009 12:38 pm
wrong! get someone who is an expert with jap cast alloy and you will never have a problem again and will be better than new.
Post Posted: Tue Sep 15, 2009 1:03 pm
seal-up, its liquid glass :)
Post Posted: Tue Sep 15, 2009 1:09 pm
Might have trouble with the welding now as the crack will be full of the stop leak rubbish
Post Posted: Tue Sep 15, 2009 2:27 pm
Seal up is what I used about a week ago, I will give it more time to see if it settles down. I do use the Zook as a daily driver.
Post Posted: Wed Sep 16, 2009 1:11 am
can anyone share anymore on this topic?? i have coolant that i have been chasing for a few weeks now that is a very very slow leak.Seems to leak down the side of the block then onto my front diff centre.I thought it was where the lower radiator hose went to the engine but tonight was thinking more the block.How much is involved in the repair?
Post Posted: Wed Sep 16, 2009 1:15 am
Check ya water pump, it has a tell tale that will leak on to the diff.
Post Posted: Wed Sep 16, 2009 1:19 am
check your core plugs as well as they can also leak.
Post Posted: Wed Sep 16, 2009 1:24 am
there is not much room to get a proper look but it seems to me as though it is the block not the water pump.You mean the little hole on the pump ???
the core plugs?more info please? in the side of the engine you mean,i have looked there but am chasing it further forward,like right up to behind the water pump
Post Posted: Wed Sep 16, 2009 1:29 am
it is a crack between number 3 and 4 cylinder. it is not common, but does happen from time to time. the only way to fix it right and to make sure it does not happen again is to get a pro tig welder to do it. you WILL have to pull the motor out as this will be the only way of doing it right. additives will not work in this application as that part of the block is also dealing with high stress loads. only tigging will fix it.
Post Posted: Wed Sep 16, 2009 1:32 am
Yep, that lil hole, could be the water pump gasket. sounds like you have a different leak to the posted leak.
Post Posted: Wed Sep 16, 2009 1:38 am
well is joes answer replying to my problem or the original posts??mine is right near the front of the engine,could possibly be the gasket or pump but im fearing it isnt that :cry: will go try have a better look if i have a bright enough torch
Post Posted: Wed Sep 16, 2009 1:43 am
no it is a rely to the original thread. if you have a leak towards the front it will be a water pump, as the vit blocks don't crack there..........but i have seen many a water pump spray its love goo all around that area.
Post Posted: Wed Sep 16, 2009 1:57 am
:rofl: Love goo!!
Post Posted: Wed Sep 16, 2009 1:59 am
thanks heaps joe youve been a great help.and the others too.
Where mine leaks to,like i said the tiniest of amounts it shows signs down the block just behind the water pump where the pipe runs out of the rear of it to the hoses.a tiny amount will pool up in the casting where it runs out to the engine mount.Still going with the water pumo idea so i can get onto it.I hate leaks
Post Posted: Thu Sep 17, 2009 3:29 am
while there is a thread going on a similar topic ill keep asking away here.today my zuk sat all day didnt get started etc but when i got home from work there was still signs of fresh fluid trickling down the side of my block as discussed in the posts above.Now without the engine running i wasnt expecting this,looks like the pipe coming out of the back of water pump or above that even.
ANY IDEAS FELLAS
Post Posted: Thu Sep 17, 2009 9:43 pm
Coolant or "love goo" dosn`t need to be under pressure to leak, start pulling things off till you find it, could be the O`ring at the end of the pipe, water pump, pump gasket, take the w/pump pulley of & have a closer looky look. :wink:
Users browsing this forum: Google [Bot] and 177 guests
