It is currently Sat Nov 14, 2026 1:47 pm
Post Posted: Sun Jan 28, 2007 7:02 pm
hey all,
Went for a bit of a trip along the beach the other day, went to shift to low range but no go. Tried several times on and off the beach but it just seemed that there was something stopping it, had a look under the car for stick jamming it as i had been through some timbered areas before the beach, but all appered well. I've never had any dramas with the transfer before apart from shifting to 2wd to 4wd and vice versa, which i guess is common for 4wd's. Any ideas what it may be and what to check for?
(96 Sierra Shorty)
Cheers :)
Post Posted: Sun Jan 28, 2007 8:02 pm
I had this happen with my sierra and the problem was the selector rails were out of alignment in the transfercase. (removed transfer lever, used screwdriver to re-align rails and it didnt do it again.)
Hopefully yours is as simple as that. :?
Vehicle: 75 Cruiser
Post Posted: Sun Jan 28, 2007 11:05 pm
have ya checked ya bush under the stick? could be stuffed? (see bruce for a new one )
I was gonna say if you bent the transfer case mounts the stick may be hitting the body stopping it from going in to gear, but you'd probably get a big vibration if the mounts were bent.
Post Posted: Tue Jan 30, 2007 2:27 am
This arvo i removed the shaft boot from inside, had a bit of a look around. The nylon/plastic ball at the bottom of the shaft appears to be ok (small amount of play), selector shaft doesnt appear to be hitting body, transfer mountings in good nick. It just appears that the selector wont move forward to shift into low range.
Mandy - How do you re-align the selector rail? Im guessing from the selector shaft at the front, it should be aligned i guess vertically as possible?
Steve - How much play is expected normally in the bush under the stick?
Thanks for the help :)
Vehicle: 75 Cruiser
Post Posted: Tue Jan 30, 2007 12:18 pm
if the bush is still there and in one peice i think it should still work ok....
now, over to you mandy :)
Post Posted: Tue Jan 30, 2007 1:12 pm
dont confuse the nylon sleeve on the very botton of the stick with the one the ball of the stick pivots on
it doesnt come out with the stick it stays in the hole, I'll bet its worn away and isnt there :wink:
what happens is it wears away, the stick falls down into the hole and pushes the selector forward due to the angle of the selector rod
Post Posted: Wed Jan 31, 2007 6:48 pm
http://bbs.zuwharrie.com/index.php?boar ... eadid=1425
This is a very informative thread for replacing bushes. (with Pics!) :)
As for the selector rails, i'm sure Royce would know. A friend of mine did it for me and i wasnt really paying much attention :oops: It only took a couple of minutes.
Post Posted: Thu Feb 01, 2007 2:14 pm
Mt new transfer case also does what Mandy is describing. It's easy to fix but painful when it happens. It's happened to me 4-5 times now. What can be done to stop it?
'85 Sierra SWB with Fibreglass hard top
30 inch M
aka
aka
Post Posted: Mon Mar 05, 2007 4:26 pm
Just had my transfer case lock up and followed the instructions on the thread
bbs.zuwharrie.com/inde...eadid=1425
and it only took me 15 minutes and I only smacked my head under the car once.
Experience is something you dont get until just af
Post Posted: Tue Mar 06, 2007 1:03 am
I went out the other week and my bush went! Got stuck in neutral so i couldn't go any where! Thought the box was stuffed but i was happy it was only $17! 8)
back in a built sierra!
Post Posted: Tue Mar 06, 2007 1:44 am
Did you pay $17 for the bush?
Post Posted: Tue Mar 06, 2007 11:49 pm
Sure did is that good or bad?
Post Posted: Wed Mar 07, 2007 3:23 am
Gee could of sold you a
1 x Transfer Case Shift Bush.
1 x Transmission Shift Bush.
1 x Ignition Timing Cover.
1 x Steering Biscuit 10mm.
All for about $30.00 :-) + Postage or you can pickup for free :-)
Remember whan ya need Polyurethane parts. I am :youdaman:
Like these ones
http://cgi.ebay.com.au/Polyurethane-Bus ... dZViewItem
Post Posted: Wed Mar 07, 2007 3:38 pm
So its only a bush that is causing this? How hard is it to replace. VERY keen to fix mine it does this all the time
30 inch M
Vehicle: 75 Cruiser
Post Posted: Wed Mar 07, 2007 5:51 pm
easy as, just take the lever out and stick the new bush in and replace the lever. The transfer gear lever is a bit more fidly to get out as compared to the gearstick, but pretty straight forward.
Post Posted: Wed Mar 07, 2007 11:41 pm
To get the lever out you have to push down and twist!
Steve how much for the gear box bush? 8)
Vehicle: 75 Cruiser
Post Posted: Thu Mar 08, 2007 11:35 am
bruce is your man :wink:
Like these ones
Post Posted: Thu Mar 08, 2007 1:20 pm
Just as easy to go to the Ebay web site and get them from them. I sell them to him so the price is as good if not better as he usually has free delivery. :-)
Post Posted: Fri Mar 09, 2007 1:11 am
Fair enough! Will check it out! Thanks! 8)
Post Posted: Fri Mar 09, 2007 1:30 am
No worries mate.
Post Posted: Fri Mar 09, 2007 3:51 pm
I've had the stick out a million times. So its just a matter of bushing a new bushon the end of the stick?
30 inch M
Post Posted: Fri Mar 09, 2007 4:02 pm
no the bush goes in the housing and the ball section of the stick pivots on it
Post Posted: Tue Mar 13, 2007 8:19 pm
I'm with ya! Have you got one laying about mate? If so PM me and I'll definatly take it off your hands!
30 inch M
aka
aka
Post Posted: Wed Mar 14, 2007 10:31 pm
Hey Guys,
Got the bush kit today and dont quite know where the Transmission Shift Bush goes. ?
Your enlightenment would be much appreciated.
Cheers,
Rapson
Vehicle: 75 Cruiser
Post Posted: Thu Mar 15, 2007 10:37 am
the transfer case stick bush goes under the ball on the gear stick.
the gearbox stick bush goes on top of the ball on the stick.
is that confusing enough ? :)
Users browsing this forum: Google Adsense [Bot] and 66 guests
