It is currently Fri Oct 02, 2026 11:24 am
Post Posted: Thu Sep 17, 2009 4:47 pm
when i reach 80kms my car starts to shake heeps and then it stops and comes again
Post Posted: Thu Sep 17, 2009 4:53 pm
i had simillar problems, and its usally a mix of allot of things.
i suggest going through and tightening every nut and bolt in the front end, then adjusting wheel bearings, check the tyre pressures and see how you go from there.
also check wheel nuts, swivel hub bearings, suspension bush's.
you may also need a wheel alignment.
weaves
Post Posted: Thu Sep 17, 2009 4:55 pm
you may need to give us a little more infor on your car and its setup. It can be caused by wheel allignment. wheel balance. incorrect castor. worn bushes etc
Post Posted: Thu Sep 17, 2009 4:56 pm
Welcome to the death wobbles!! :lol:
Things to check:
-Balance all wheels
-Check ALL joints in steering for play
-Check steering box for play
-Check all wheel bearings
-Check swivel bearings and seals
-Check tyres for out-of-round/delaminating etc
There's probably something else I've forgotten but this is a good start.
I did :roll:
-Check all suspension bushes and u-bolts (if it's a leafy)
Post Posted: Thu Sep 17, 2009 5:02 pm
Things to check:
-Balance all wheels
I did :roll:
And kingpin bearings 8)
Vehicle: 75 Cruiser
Post Posted: Thu Sep 17, 2009 5:03 pm
and make sure your shackle nuts are done up :oops:
Post Posted: Thu Sep 17, 2009 5:06 pm
ok thanks guys.
i have and 89 wt with 215s 2inch suspension 2inch body lift. about to get 31s and i have a tuff dog return to centre in
and i herd yestedday that your sapose to get a wheel alignment after that but i havent. is that true
Post Posted: Thu Sep 17, 2009 5:08 pm
not specifically after any of that but it will be one of the steps to fixing the death wobbles
Post Posted: Thu Sep 17, 2009 5:27 pm
and when you get an alignment tell them to set toe at 0mm. trust, this works.
Post Posted: Thu Sep 17, 2009 5:32 pm
Joe would this also help with exessive wear on the outside of the front tyres?
as my Sierra has had wheel alignments done to 1mm toe in, essentially everything replaced in the front end (except steering box, which I'm doing ATM), and I still get occasional death wobbles, and too much tyre wear on the outside of the front tyres.
Clearance Hole Technology :P
Post Posted: Thu Sep 17, 2009 6:22 pm
:wink: I called them something else :lol:
Post Posted: Thu Sep 17, 2009 8:19 pm
it might, but that can also be a castor/ camber related issue.
Post Posted: Thu Sep 17, 2009 11:32 pm
can extended shackles with no braceing in the middle give you wobbles in the front end ?
cheers brodie
100 series cruiser 4 inch lift and 35s
1990 sierr
Post Posted: Fri Sep 18, 2009 12:36 am
cheers brodie
Yep
Users browsing this forum: Google Adsense [Bot] and 118 guests
