It is currently Fri Oct 02, 2026 7:20 am
Post Posted: Thu Sep 17, 2009 11:41 pm
hi i was wondering when fitting commodore shocks to a lwb vitara do u need a new bolt on the bottom part for the shock? as mine dont fit throught the commodore shock
Post Posted: Fri Sep 18, 2009 12:40 am
push out the roll sleeve from the bottom bush in the vitara shock & insert into the commonwhore shock after removing the commonwhore one.
a vice & a couple of sockets will make this easier.
Post Posted: Fri Sep 18, 2009 1:48 am
sweet thanks mate
Post Posted: Fri Sep 18, 2009 11:51 am
What brand do you have Tombutt? Damo had the same problem but mine fitted straight on :?
Post Posted: Fri Sep 18, 2009 12:19 pm
mine were fine as well. i used KYB vs wagon rears. maybe the vits have smaller pins.
Vehicle: SJ51T
Post Posted: Fri Sep 18, 2009 12:28 pm
i just did this with monroe commo shocks.. i had to shave a bit off the bush out to get the vitara sleeve in as it was just pusting the bush out. and i had to belt a screwdriver around the sleeve in the vitara shock to get it out.
Post Posted: Fri Sep 18, 2009 8:36 pm
um i have gabriel (dont think tats spelt right) they are jsut the super cheap ones and the bolts in a vitara at too big to go throught commodore bushing. deffinatly a worth while mod the flex is awesome
Post Posted: Fri Sep 18, 2009 8:53 pm
i hope you're running extra long coils as they might fall out & bumpstop extensions would be a good idea...
Users browsing this forum: Google [Bot] and 116 guests
