It is currently Tue Oct 06, 2026 9:20 am
Post Posted: Sun Sep 20, 2009 3:16 am
Today driving the zook the steering seems to be a bit stiff and sticky in a certain spot what could cause this. It may be a coincident but i have no drive to the front right wheel as its locked it should have drive. I was thinking it might be my cv but i have not heard anything (breakages etc) it also has vit power steer has anyone experienced this
Post Posted: Sun Sep 20, 2009 3:56 am
Are the unis/ rag joint on your steering shaft moving freely? Sometimes the vit box can cause this prob due to its offset output. You may need to fit a wedge bracket to re-align the output shaft with the steering shaft.
Or it could be a CV if you have no drive.
Post Posted: Sun Sep 20, 2009 1:35 pm
I run 2 unis on my steering shaft to compensate for the angle of the box and the problem only started yesterday. Also the fact that i havent driven it witht the hubs engaged for a fair while seems a bit funny that it would be a cv it was all working fine last time i went 4x4ing. And all the bearings are good.
Vehicle: '92 Sierra
Post Posted: Sun Sep 20, 2009 4:52 pm
I'll put money on one of the steering shaft uni's seizing up. I had the exact same symptoms.
Post Posted: Sun Sep 20, 2009 6:00 pm
ok i will check the unis out and see how i go thanks for the help
Post Posted: Sun Sep 20, 2009 11:46 pm
you'd have won the bet mate lol
Users browsing this forum: Google [Bot] and 240 guests
