It is currently Tue Oct 06, 2026 11:13 am
Post Posted: Sun Sep 20, 2009 6:04 am
just wondering i am about to do an engine conversion putting a 1.6 carby in my sierra i have heard you need to put the 1.3 sump on the 1.6 because there isn't enough clearance, i have a spoa lift do you think i will be able to fit the 1.6 sump or will i still need to change them over?
Post Posted: Sun Sep 20, 2009 11:45 am
That depends a bit on how your SPOA is set up, but there's normally plenty of room to use the 1.6 sump.
I've seen some very low and unbumpstopped spoa's with 1.6 sumps.
Post Posted: Sun Sep 20, 2009 1:24 pm
i have a spring under SWB with a 1.6 and have no problems with sump clearance however i
have moved my diff forward a fair bit. it only has 25mm bumpstops as well
Post Posted: Sun Sep 20, 2009 9:36 pm
if i do need to change the sump is it a stright swap over
Post Posted: Sun Sep 20, 2009 10:06 pm
sump yes. oil pickup no.
Post Posted: Sun Sep 20, 2009 11:06 pm
There's cutting and welding involved in swapping the oil pickup over.
Good point shep - RUF, for instance, helps a lot.
Post Posted: Mon Sep 21, 2009 1:07 am
is there any info on how to swap the oil pickup over or could someone give me a run down
Users browsing this forum: UBZ and 139 guests
