It is currently Tue Oct 06, 2026 2:50 pm
Post Posted: Wed Sep 23, 2009 3:20 pm
Does anyone know how to remove the plastic interior trim on the drivers side A pillar?
I've sorta got it off on the door side but there seems to be a few clips somewhere holding it down.
FWIW it's a 2002 GV.
Cheers.
2002 SWB GV
Lifted and Locked
Post Posted: Wed Sep 23, 2009 4:17 pm
http://www.outerlimits4x4.com/ftopic187 ... 5d24ca013d
Post Posted: Wed Sep 23, 2009 4:36 pm
Just pull it. hard. thats if its similar to the SWB, I have pulled some of them off, but not in My LWB.
If your not breaking shit, try harder!!!
Post Posted: Wed Sep 23, 2009 9:32 pm
Link`s to outer`s only work if your a member......
X2 on Mugwui, plastic clip`s hold the plastic trim to the a pillar, but 1st step is to remove the step panel`s, then the trim pull`s off.
Post Posted: Wed Sep 23, 2009 9:39 pm
same question was asked on outers & i thought i answered it there?
the thing is held on with 3 christmas tree plugs or similar plugs, it's been a few years since i had mine off.
Post Posted: Wed Sep 23, 2009 9:43 pm
But you boy`s bag it so much that I`m not a member, so can`t looky, or any other non member, not that i care to , just mentioned it , valve cap.
Post Posted: Wed Sep 23, 2009 10:12 pm
i don't bag outers, that's the sierra guys... :roll: :wink:
fuck you & your genuine suzuki valve caps. :finger: :finger: :finger: :finger: :finger: :finger: :finger: :finger: :finger: :finger:
Post Posted: Wed Sep 23, 2009 10:13 pm
That`s not nice..... :cry: :cry:
What is it with outer`s?? Is it worth a look???? :?
Post Posted: Wed Sep 23, 2009 10:20 pm
Sorry, i need to complete my collection. Surely you can spare a right hand rear valve cap?
Outers is alright, but it's no Auszookers! Armsup Armsup
Post Posted: Wed Sep 23, 2009 10:45 pm
I`ll stay here then :roll: .
What model would you like?? :wink:
Post Posted: Wed Sep 23, 2009 10:48 pm
Fuck outers...."Out of Options" as I like to call it.
Post Posted: Wed Sep 23, 2009 10:51 pm
Vitara & Gv agree, I stay ere then :cheers: pompoms
Post Posted: Thu Sep 24, 2009 4:10 pm
Which piece is the step panel you mentioned? Is this the one down in the footwell as I'm not sure how those pieces are connected since there's a dash in between?
2002 SWB GV
Lifted and Locked
Post Posted: Thu Sep 24, 2009 10:51 pm
The bit you "step" on when getting in, I had a look at mine today & there is 3 clip`s that hold it on,,, Get a good torch & stick ya head in & you will see them, sum types of clips just pull out, others need a screw driver, others the center push`s in then th whole clip comes out....
Post Posted: Fri Sep 25, 2009 12:08 am
I vote we limit Steknig to 1 post a day!! Way too many posts here 8O 8O 8O
Post Posted: Fri Sep 25, 2009 12:42 am
I`m shocked to say the least.. & now I`ve had to reply to your comment about my posting, making more post`s it this thread.
Post Posted: Fri Sep 25, 2009 12:43 am
I WILL CATCH ATARI !!!!!
Valve cap pompoms pompoms pompoms pompoms pompoms pompoms
Post Posted: Fri Sep 25, 2009 4:47 pm
I think we're getting confused here. I'm referring to the plastic panel that covers the A-pillar next to the windscreen. You're referring to the panels down at foot level. I've pulled the foot-level panels out before, that's no problem.
I can't see any plastic clips on the A-pillar plastic bit which is my problem.
2002 SWB GV
Lifted and Locked
Post Posted: Fri Sep 25, 2009 5:13 pm
They aren't visible from the outside, just start from the top & work your way down. You will find them, just be gentle pulling it away from the pillar to find the clips.
Post Posted: Sat Sep 26, 2009 4:43 am
I actually did this the other day (was wondering if i could mount a grab handle)
Stick your fingers in between the rubber door seal and the trim - you should be able to do this quite easily on the cieling end of the trim (not the dash end)
The trim has 3 xmas tree type plugs, closer to the windscreen side- and they're in quite tight! normally you'd just give it a good yank and it'll pop out - not this one.
I used a screwdriver, stuck it in from next to the door seal, put it next to the plug, and pushed the plug out (rather than pulling it out as its in so tight you'll probably bend/crack the trim).
Once the first one is out, the others are fairly easy.
Just a tip - when looking for the first plug, you may need a torch as its a bit hard to spot will all the cardboard packing etc thats in there
Post Posted: Mon Sep 28, 2009 3:16 pm
Great thanks for that Shabz.
One more question, do the plugs go in from the side (parallel to the windscreen) or from the back of the pillar?
2002 SWB GV
Lifted and Locked
Post Posted: Mon Sep 28, 2009 4:04 pm
the plugs are captive in the trim & would be in line with the pillar if you know what I mean.
Just have a look, it will be pretty obvious once you look at it!!
Post Posted: Fri Oct 02, 2009 4:39 am
Hmm....how to explain this...
The plugs go into the side of the pillar from the centre of the dash. Meaning if you were sitting in the drivers seat, you will need to pull the trim off towards the dash - rather than down...if that makes sence.
Find the plugs as i said before, and it'll make sence when you see it
Users browsing this forum: No registered users and 151 guests
