| 1.6 carb fuel pump problem http://auszookers.com/forum/viewtopic.php?f=5&t=6871 |
| Author: | lukes_89 [ Sat Sep 26, 2009 11:46 pm ] |
| Post subject: | 1.6 carb fuel pump problem |
hey guys my engine swap is basicaly complete for some reason my starter motor is giving me troubles not sure why yet its just making a clunking noise but had it tested and is suposably fine :S. but the main problem is the fuel pump i took the fuel pump off and i have placed it back on and now its not pumping :S just wondering can any one explain how the pumps work and what moves the lever from what i can see i thought it was oil pressure that flowed into the pump moved the lever not sure though just a guess but if any one has any idea on how to fix it thanks luke |
| Author: | steak_knife [ Sat Sep 26, 2009 11:48 pm ] |
| Post subject: | Re: 1.6 carb fuel pump problem |
It`s a 8 valve? sounds like the push rod in the head fell out, have a look under the car. |
| Author: | lukes_89 [ Sat Sep 26, 2009 11:52 pm ] |
hey thanks for the quick reply whats the push rod does it sit inside the little hole thsat sits up against the lever?? |
| Author: | steak_knife [ Sat Sep 26, 2009 11:58 pm ] |
Yes. That`s the one! If that`s in you may not be geting the lever against it properly, thay can be temperamental. |
| Author: | lukes_89 [ Sun Sep 27, 2009 12:03 am ] |
yeh nah ive lost the pin out of both engines can you explain what they look like so i can start my hunt for this pin thanks so much for the quick replys and help |
| Author: | steak_knife [ Sun Sep 27, 2009 12:09 am ] |
It`s just a small tubular piece om metal, Can`t remember how long. bout 4-6 cm long from i think |
| Author: | zookster666 [ Sun Sep 27, 2009 12:10 am ] |
they are a short steel rod same diameter as the hole and about 40-50mm long |
| Author: | lukes_89 [ Sun Sep 27, 2009 12:12 am ] |
ok awesome to the garage the search begins then i just have to fix the starter motor problem then im back out 4x4ing cant wait thanks so much guys |
| Author: | steak_knife [ Sun Sep 27, 2009 12:16 am ] |
got any pic`s of you car???? We like pic`s |
| Author: | Rusho [ Sun Sep 27, 2009 12:24 am ] |
You interested in a wheel at the g'house. Check out my post in trips & travel. Good luck with the fuel pump mate. I found it easier to make sure the pin(moves on cam rotation)is out a fraction from its locating hole and locate the arm on the pin, put bolts in and do up from side to side gradually. Not sure how other blokes do it but it worked for me. Hope this makes sense and helps you out a bit. |
| Author: | lukes_89 [ Sun Sep 27, 2009 12:45 am ] |
ok awesome i have a few at home ill put them up later and put up what shjes got and so forth for you guys shes just a stoko atm besides engine need the money but def keen for a run in the glass house mountains but i hope you like pulling me oput lol i only got road tyres atm as i said stoko lol. but yeah thanks for your help guys |
| Author: | steak_knife [ Sun Sep 27, 2009 12:53 am ] |
lukes_89 wrote: ok awesome i have a few at home ill put them up later and put up what shjes got and so forth for you guys shes just a stoko atm besides engine need the money but def keen for a run in the glass house mountains but i hope you like pulling me oput lol i only got road tyres atm as i said stoko lol. but yeah thanks for your help guys
peaceout peaceout peaceout
Is that your 1st Suzuki?? |
| Author: | Rusho [ Sun Sep 27, 2009 12:57 am ] |
More than welcome mate...I know 1/10th of what some guys on this site, but i like to give feedback on the little i do. This site has helped me learn a lot already, it is excellent. Don't worry about the stoko thing you'll be alright. Don't be affraid of asking 'stupid questions either" I have, you may cop a bit of shit, but you always get the answer you need. |
| Author: | lukes_89 [ Sun Sep 27, 2009 5:10 am ] |
yeh she is my first 4x4 ive gone form rice burner to my new zook and i absolutley love it |
| Author: | Rusho [ Sun Sep 27, 2009 12:22 pm ] |
Go 30's mate..less hastle, snugger fit. 31's can rub, not saying they will but can. |
| Author: | steak_knife [ Sun Sep 27, 2009 3:42 pm ] |
Talk to just-cruising for boby lift. link below.. http://www.auszookers.com/index.php?nam ... pic&t=6186 |
