It is currently Thu Oct 08, 2026 5:54 pm
Post Posted: Sun Sep 27, 2009 1:13 pm
is it a straight swap to put a WT dash in a NT?
Post Posted: Sun Sep 27, 2009 1:18 pm
i think all the bodies are the same its just the axles and flares that make them WT/NT
Post Posted: Sun Sep 27, 2009 1:20 pm
1 litre to WT you need to weld some brackets in, 1.3 NT to WT might go, at worse youll need to ziptie some stuff in :)
Post Posted: Sun Sep 27, 2009 1:26 pm
zip ties, i am not that flash. :wink: :D
i cant find a glove box lid for the NT so i might stick a wt dash in. 8O
Post Posted: Sun Sep 27, 2009 1:49 pm
i was wrong...
Post Posted: Wed Sep 30, 2009 11:41 pm
wt and nt bolt up the same you just need to change wiring aswell because i think the gauges use a different plug but then the fire wall plugs change too
but other then that the dashes can be swaped
Vehicle: 75 Cruiser
Post Posted: Thu Oct 01, 2009 12:48 am
yeah shep i have done this a few times, all basicly the same. There's a couple little things that are different but nothing to worry about. I think the clock is in a different position so you have to stretch the wiring to the clock a bit.
Users browsing this forum: No registered users and 169 guests
