| WT/NT dash http://auszookers.com/forum/viewtopic.php?f=5&t=6878 |
| Author: | shep [ Sun Sep 27, 2009 1:13 pm ] |
| Post subject: | WT/NT dash |
is it a straight swap to put a WT dash in a NT? |
| Author: | 31zook [ Sun Sep 27, 2009 1:18 pm ] |
| Post subject: | Re: WT/NT dash |
i think all the bodies are the same its just the axles and flares that make them WT/NT |
| Author: | royce [ Sun Sep 27, 2009 1:20 pm ] |
1 litre to WT you need to weld some brackets in, 1.3 NT to WT might go, at worse youll need to ziptie some stuff in |
| Author: | shep [ Sun Sep 27, 2009 1:26 pm ] |
zip ties, i am not that flash. i cant find a glove box lid for the NT so i might stick a wt dash in. |
| Author: | 31zook [ Sun Sep 27, 2009 1:49 pm ] |
i was wrong... |
| Author: | bazook [ Wed Sep 30, 2009 11:41 pm ] |
wt and nt bolt up the same you just need to change wiring aswell because i think the gauges use a different plug but then the fire wall plugs change too but other then that the dashes can be swaped |
| Author: | steve [ Thu Oct 01, 2009 12:48 am ] |
yeah shep i have done this a few times, all basicly the same. There's a couple little things that are different but nothing to worry about. I think the clock is in a different position so you have to stretch the wiring to the clock a bit. |
