| starter motor problems?? 1.6 into sierra http://auszookers.com/forum/viewtopic.php?f=5&t=6890 |
| Author: | lukes_89 [ Mon Sep 28, 2009 12:00 am ] |
| Post subject: | starter motor problems?? 1.6 into sierra |
hey guys finally got my car running today |
| Author: | bigrig91 [ Mon Sep 28, 2009 12:20 am ] |
| Post subject: | Re: starter motor problems?? 1.6 into sierra |
does it turn over, start then make a grinding noise for 2 to 3 seconds then stop?? if so, you will just need to pull it out, take it apart, note the way the fork that throws the bearing in and out came out like, then clean and grease it all up again. put it back together and bam all fixed. hope that helps. |
| Author: | lukes_89 [ Mon Sep 28, 2009 12:58 am ] |
No when you go to start makes a loud squelling noise amd sometimes it tries to turn over and again makes a really loud clunking noise. When push start its fine something to do wqith starter. |
| Author: | oozuk [ Mon Sep 28, 2009 2:09 am ] |
did you use a sierra starter or a vitara reduction starter ? because the sierra starter foul's on the 1600 block and requires grinding of either the block or the starter motor, if this isnt done then it causes misalignment of the starter motor and incorrect meshing of the starter to the ring gear. So your choices are either grind back your starter where it fouls on the block, or Find a 1600 reduction starter as they bolt straight in and clear everything and have more torque than the 1300 sierra starter, thus making them a better starter and longer lasting |
| Author: | lukes_89 [ Mon Sep 28, 2009 3:12 pm ] |
oozuk wrote: did you use a sierra starter or a vitara reduction starter ? because the sierra starter foul's on the 1600 block and requires grinding of either the block or the starter motor, if this isnt done then it causes misalignment of the starter motor and incorrect meshing of the starter to the ring gear. hey im not sure as its a new engine that could quiet possibly be the problem i will check the old block and see if he has grinded the block down as i have only ownd the car for like a month and it has always had the swap thanks for your help will let you know how i go. Do you know where i could get a new starter from either secondhand or new. Have rang a few places and no one seems to have one.
| Author: | losfer [ Mon Sep 28, 2009 11:02 pm ] |
you rang me this afternoon didnt you... |
| Author: | lukes_89 [ Tue Sep 29, 2009 12:17 am ] |
i spoke to 2 places today and no said that they had one, someone said they think they have one and will ring tomorrow if they do hopefully thats you and can get one. |
| Author: | steak_knife [ Tue Sep 29, 2009 12:58 am ] |
So your choices are either grind back your starter where it fouls on the block, or Find a 1600 reduction starter as they bolt straight in and clear everything and have more torque than the 1300 sierra starter, thus making them a better starter and longer lasting X2 |
| Author: | bron5on [ Tue Sep 29, 2009 1:17 pm ] |
So your choices are either grind back your starter where it fouls on the block, or Find a 1600 reduction starter as they bolt straight in and clear everything and have more torque than the 1300 sierra starter, thus making them a better starter and longer lasting Sorry to hijack but does anyone have a part number for the 1600 reduction starter? All the vit ones i've found down here have the same starter as my sierra. I'm running a modified colt (not 100% sure) starter but i'd prefer the 1600 option. I didn't fancy taking to my block with the grinder to fit the sierra one! Cheers! Bronson |
| Author: | BenT [ Tue Sep 29, 2009 7:08 pm ] |
bron5on wrote: Sorry to hijack but does anyone have a part number for the 1600 reduction starter?
M1T72481 31100-60A20 Ben |
| Author: | oozuk [ Tue Sep 29, 2009 10:22 pm ] |
its from the efi 1600 vitara |
| Author: | losfer [ Tue Sep 29, 2009 11:06 pm ] |
lukes_89 wrote: i spoke to 2 places today and no said that they had one, someone said they think they have one and will ring tomorrow if they do hopefully thats you and can get one.
i dont have one but i am waiting on a shipment , they shouldnt be too far away , possibly in the next couple of days. |
| Author: | bron5on [ Wed Sep 30, 2009 1:38 am ] |
BenT wrote: bron5on wrote: Sorry to hijack but does anyone have a part number for the 1600 reduction starter? M1T72481 31100-60A20 Ben Thanks muchly! My vit 16v vit motor came with the chunkier sierra style starter. And when I tried to buy a new starter from the auto elecs they couldn't get the slimmer style model and told me they had probably been superseded? |
| Author: | 89_tintop [ Wed Sep 30, 2009 2:13 am ] |
hey i can get the reduction starters.... brand new |
| Author: | steak_knife [ Wed Sep 30, 2009 2:19 am ] |
89_tintop wrote: hey i can get the reduction starters.... brand new
I was waiting for you to notice this. Can you get me a price on a Gv SQ625 please? |
| Author: | ajsr [ Wed Sep 30, 2009 2:30 am ] |
how much $$$ cheers |
| Author: | bron5on [ Wed Sep 30, 2009 2:41 am ] |
ajsr wrote: 89_tintop wrote: hey i can get the reduction starters.... brand new how much $$$ cheers X2 |
