http://auszookers.com/forum/
Speakers
http://auszookers.com/forum/viewtopic.php?f=5&t=6947
Author:  303zuke [ Wed Sep 30, 2009 5:00 pm ]
Post subject:  Speakers
Don't want to get into a discussion about full-on Doof-Doof car stereos here, but what decent sounding replacement speakers will fit directly into the original holes in the front of a Sierra? I don't really like the idea of cutting holes in the rear trim cards to mount 6"x9"s in the back, just something for the front, but I want as good a sound as possible.
What have people found?
Author:  tanshi [ Wed Sep 30, 2009 5:07 pm ]
Post subject:  Re: Speakers
should be able to get a good set of 6 inch splits in the front pretty easy.
Author:  royce [ Wed Sep 30, 2009 5:22 pm ]
Directly into the holes is 6"
massive improvment if you deaden than chamber and mount the speakers on an MDF panel over the original hole
if you dont mind a bit of cutting a 6x9 will fit down there
if you dont mind a lot of cutting a 6 and an 8 will fit down there :)
Author:  wyt91t [ Wed Sep 30, 2009 6:30 pm ]
what do mean make a box for it to sit into...
Author:  nick.gooding [ Wed Sep 30, 2009 10:26 pm ]
you can buy boxes that screw to the body over the preexisting hole. they screw over it and you can put 6x9's into them.
Author:  Shelby [ Wed Sep 30, 2009 10:47 pm ]
spercheap just got in catalogue, Fusion 6"s with tweeters and the lil amp thingy's to make it sound better for $100
Author:  twitchy [ Thu Oct 01, 2009 1:41 am ]
Pioneer still make one of the best "Component" speakers on the market......... not that dear anymore either.
Author:  royce [ Thu Oct 01, 2009 1:58 am ]
no boxes just a flat panel, I am sure there is a pic on here somewhere
Author:  ZOOKCREW [ Wed Oct 21, 2009 10:24 pm ]
ive got pioneer 6x9 s in boxes that i bought from supercheap ... i just bolted them down to where my rear seats were.
Author:  bron5on [ Thu Oct 22, 2009 12:45 am ]
Royce, how did you go about deadening the chamber? Just packing it with loose dacron or something?? I've got 4" speakers in small boxes that i made, one screwed to the parcel shelf under the dash and the other bolted under the dash next to the ignition. I had to trim the dash a bit (with the saw blade on my leatherman!) to make it fit and attack some useless looking bit of metal with the grinder but I got it in there. I wouldn't recommend it tho, the amount of times i've driven my knee into the pointy corner of the box while climbing into the seat... Time for a change!
Author:  lukes_89 [ Thu Oct 22, 2009 1:04 pm ]
the guy i brought my zook off installed a set of splits put the woofer component in the door in original space and then he cut a small hole under the dash pretty much under steering wheel for drivers tweeter and then in then under the little box for storage on passenger side and put them in nice and flush cant even tell they are there if you done point them out its really good no i just need some splits for my rear end and hopefully a lill 8 or 10inch sub maybe under the drivers side seat or under the rear passanger seats maybe. p.s ive always owned a rice burner with a huge sound system pulling 160db with a15inch subs and now i just need the lill sub to give some better sound quality :P
Author:  Ridge [ Thu Oct 22, 2009 4:32 pm ]
good luck fitting a sub under a seat in a zook. my amp just fits in under mine. i have mtx 6.5" splits in the front with the tweaters mounted on the dash and 6x9s on pods on plywood panels in the back.
Author:  paulv [ Thu Oct 22, 2009 6:45 pm ]
I installed 6.5" Jaycar speaker in the front kick panels of my coily.
Jaycar 6.5"
Screwed some speaker spacers to the panel first:
Aerpro
Looks good, however speaker on the drivers side ends up mighty close to the fuse box thing.
Author:  Saam [ Thu Oct 22, 2009 7:05 pm ]
i got the airsaw out, and made the holes in the kick panels bigger, i have 6.5 inch alpine type r's in there, come nowhere near the fusebox and i am yet to kick one in, they have been there for 2 years HORAAHH
previous model to these, got them for $80 off of a mate who was stripping his show car ! :D
