It is currently Tue Oct 06, 2026 9:38 am
Post Posted: Wed Sep 30, 2009 8:36 pm
I want to build some armour for my fuel tank now that I got it's capacity back. I was just wondering if someone here has built one and post up some sort of drawing with measurements?
I'm in the process of trying to devise something like the shrockworks gaurd, but if somebodys already got the plans for one, it'll save me a lot of time.
Vehicle: MY2019 Jimny
Post Posted: Wed Sep 30, 2009 8:53 pm
A guy was selling some here a while back, looked like folded gal sheet. Haven't seen him for a while...
Post Posted: Wed Sep 30, 2009 9:02 pm
I think I saw them and they looked a little weak to me. I was planning on using 4 or 5mm sheet
Post Posted: Wed Sep 30, 2009 9:05 pm
I will have a test piece ready in a week or so. I will try to get a 3D model up tonight. Its along the same lines as the shrockworx one, only cooler 8)
Post Posted: Wed Sep 30, 2009 9:25 pm
I'll test it for ya Pete :wink:
Post Posted: Wed Sep 30, 2009 9:44 pm
Mine is made from 6mm plate steel. :comeon:
I didn't make it, but whoever did did a brillant job. I can measure out each separate section for ya on the weekend if ya like. 6mm is like a bit of overkill, 5.5mm should be plenty :P
Each section is just flat steel welded together. Pretty easy for a backyard stick welder.
Post Posted: Wed Sep 30, 2009 9:59 pm
Build it and they will come :lol:
Post Posted: Wed Sep 30, 2009 10:00 pm
& you`ve always got a bbq with you :roll:
Post Posted: Wed Sep 30, 2009 10:01 pm
Let me know when you have one for sale, I want one.
Post Posted: Wed Sep 30, 2009 10:24 pm
Just viewed the 3D model and its fully sick peaceout . I just have to convert the image to a jpg. then I'll chuck it up here 8)
Post Posted: Thu Oct 01, 2009 12:51 am
who does tank protection for vitara's?
Post Posted: Thu Oct 01, 2009 1:37 am
Noone cares about them! :roll:
I'd be in for one, and i'd replace my dented tank and do it whilst the tow bar is off. so i only do it once.
Post Posted: Thu Oct 01, 2009 1:42 am
:finger:
so your all packed & ready for a epic weekend in the dunes?
Post Posted: Thu Oct 01, 2009 1:52 am
Yeah moana dunes peaceout
Post Posted: Thu Oct 01, 2009 2:42 am
If someone can lend me a vitara for a few hrs I can knock some up. If the SWB and LWB vit tanks are different I would need one of each to measure, and then trail fit once they were made.
Pete
Post Posted: Thu Oct 01, 2009 3:09 am
Cool thanx. That's just what I'm looking for. It's similar build to what I was thinking.
@ Fatzook I'm also intersted in seeing your design. I've spent a little bit of time nutting out a bit of rough sketch with some measurements this arvo and I'm interested in comparing to others
Post Posted: Thu Oct 01, 2009 3:35 am
(I have a vit tank)
I made a sample tank guard out of cardboard.and taped together to suit.
I used 4-5mm plate cut into pieces so i could weld them together.
I also left a gap inbetween the tank and guard for easy cleaning.
I was also going to bend up some 50x4 flatbar into straps for reinforcing for all the welded plates. But i thought it might be alittle overkill, however i did reinforce the top edges to one another. And reinforced some welded bends with bits of triangular plate. As seen in pics.
Post Posted: Thu Oct 01, 2009 3:58 am
i made one for my vit out of 4mm checker plate i found at work sitting there doing nothing and belonging to no-one it was a score. i will see if i have some pics laying around as it looks nothing like the previous pics..
and dont forget guys, it was a backyard job..
Vehicle: 94 Vitara LWB
Post Posted: Wed Oct 07, 2009 1:33 am
Pete
Hi Pete
I have a LWB Vitara if you want to measure up.
I 'm also just around the corner . So any time your free.
Peter
Post Posted: Wed Oct 07, 2009 3:14 am
Checker plate sucks ass, grabs friggin everything and won't slide. If you get it for nothing use it flat side down.
Post Posted: Sat Oct 10, 2009 5:50 am
just_cruizin wrote:
[Checker plate sucks ass, grabs friggin everything and won't slide. If you get it for nothing use it flat side down.
You have a point there just_cruizin but i didnt think of this at the time..
here are some pics i took if off the car as it needs a clean up and respray.
i made this about 4 years ago from 5mm Checker Plate and some old bed frame i found during council pick up after a branch i ran over decided it to wanted to be in my fuel tank. i didnt have access to a stell bender either so i stuck with a simple design.
i love bash plates..
Post Posted: Sat Oct 10, 2009 11:43 am
lol. Thats exactly what I'm making my tank armour from. 5mm checker plate and an old bed frame. All I could get from my metal merchant at the time was checker plate offcut, and I did'nt have enough cash left over for angle, so I went to my dads place, who is a unashamed horder and found an old bed frame I could use for the angle. All I gotta do now is cut the checker plate up into the sizes I want and weld it all together. I think I'll take Just_cruizin's advice and use the flat side of the checkerplate
Users browsing this forum: No registered users and 186 guests
