| Author |
Message |
Rusho
Joined: Sun Aug 02, 2009 11:30 pm Posts: 6501 Location: Northside, Brisbane
 Posted: Fri Oct 09, 2009 1:48 am |
Hi all,
Please be nice..My mate is doing an engine swap in his 3.0l Td patrol(i beg of you, please be nice) it is a 2000 model, he has aquired a 2005 model engine 3.0Td. The question is will it fit electronically and physically? Will the cylinder head be the same as I think we need to utilise his old one? Anything else we might need to know would be great.
I know I will cop a fair bit of shit for posting this, I hope I get some useful info out of it as i know that there are some very intelligent people on here(insert emoticon of asskissing here)
Thanks in advance...PLEASE BE NICE!
_________________ Shep is a closet jimny lover!!!!
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Fri Oct 09, 2009 1:54 am |
Should just be astraight swap. As far as I know they didn't change till the common rail came in.... I could be wrong
v.w.dave
Joined: Sun Sep 27, 2009 11:30 pm Posts: 1437 Location: The Hills Sydney
 Posted: Fri Oct 09, 2009 2:15 am |
They are the same motor Just all the sensors and componants are different, They were made more eco freindly. If you have the wire harness and computer you should be fine. I am not sure about wiring going to the dash or anything like that.
And I think the EGR setup is different,
_________________ Snap-On Dealer let me know if you need anything.
Scrawny
 Posted: Fri Oct 09, 2009 2:19 am |
Bah!! Who needs emission crap anyway??
Rusho
 Posted: Fri Oct 09, 2009 2:23 am |
What if we just used it as a short motor conversion. He has near new turbo, intercooler a/market computer and chip all installed.
Scrawny
 Posted: Fri Oct 09, 2009 2:25 am |
Rusho81 wrote: What if we just used it as a short motor conversion. He has near new turbo, intercooler a/market computer and chip all installed.
That's what I'd do. What's wrong with the old motor? Apart from being a ZD30
Rusho
 Posted: Fri Oct 09, 2009 2:40 am |
It's one of those magical unicorn engines that about 4 or 5 mechanics/ diesel specialist/ turbo specialists cannot put a finger on. Keeps blowing a gasket up top somewhere, will find out which one exactly. Blows a bit of black smoke, still drives really well though, even with the engine light constantly on!
royce
 Posted: Fri Oct 09, 2009 11:14 am |
Sounds like the pin is about to fall out of the Grenade
they gunk up the EGR or something and the turbo pumps too much and they go bang
I would put a G16 in it
Rusho
 Posted: Fri Oct 09, 2009 11:17 am |
Egr gasket Scrawny.... Definately makes sense now Royce. Cheers
BAZZOOK
Joined: Sat Mar 24, 2007 10:30 pm Posts: 1052 Location: MORNINGTON. VIC
 Posted: Fri Oct 09, 2009 12:34 pm |
Rusho
 Posted: Fri Oct 09, 2009 2:11 pm |
royce wrote: Sounds like the pin is about to fall out of the Grenade  they gunk up the EGR or something and the turbo pumps too much and they go bang  I would put a G16 in it
Can the EGR be bypassed? How hard and cost wise is a G16?
royce
 Posted: Fri Oct 09, 2009 2:38 pm |
from what I understand of it the turbo doesnt have a wastegate, the ecu alters the pitch of the vanes to adjsut how much air it pumps and therefore boost, problem seems to be the ecu doesnt measure actual pressure anywhere just know this revs, this throttle position, this vane angle.
Problem comes about in that it assumes a certain amount of exhuast is going into the EGR not the turbo, the EGR clogs up so then the turbo spins harder = more boost = pin falls out of the grenade and BANG!!!!
Rusho
 Posted: Fri Oct 09, 2009 5:17 pm |
So a manual boost control with some kind of wastegate set up
that has a predetermined point at which it pops, eg at 16 psi
or something like that??
LAY80N
Joined: Tue Jul 28, 2009 11:30 pm Posts: 455 Location: Newcastle NSW
Vehicle: I drive your mum
 Posted: Fri Oct 09, 2009 7:14 pm |
Rusho81 wrote: royce wrote: Sounds like the pin is about to fall out of the Grenade  they gunk up the EGR or something and the turbo pumps too much and they go bang  I would put a G16 in it  Can the EGR be bypassed? How hard and cost wise is a G16?
G16 is a suzuki 1.6L 4 cylinder - someone was having a zook themed joke
The EGR can be bypassed i think, check the patrol forum there is a good thread on the ZD30 boost control system and opperation there (forgotten the link sorry).
Layto....
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Fri Oct 09, 2009 11:48 pm |
Rusho81 wrote: So a manual boost control with some kind of wastegate set up that has a predetermined point at which it pops, eg at 16 psi or something like that??
that is exactly what you need. it is an excess of boost that blows these things up, control the boost and they will run for a lot longer. They actually have the exact same engine as the navara's but the nav's run a smaller turbo and have been set up better, might be worth a look at how the navara's control their boost.
Rusho
 Posted: Fri Oct 09, 2009 11:53 pm |
Thanks a lot for your extremely answers to my non-zook question. Keep the ideas flowing please people.
Scrawny
 Posted: Sat Oct 10, 2009 1:19 pm |
Zook_Fan wrote: They actually have the exact same engine as the navara's but the nav's run a smaller turbo and have been set up better, might be worth a look at how the navara's control their boost.
From what I'm told the Navara engine is built by Renault, the Patrol engine is Nissan. Still the same ZD30 motor, just better built by Renault.
