It is currently Fri Nov 06, 2026 3:37 am
Post Posted: Sun Dec 11, 2011 6:05 am
I have a 1991 1.6lt EFI vitara, 4spd automatic... It wont go into 1st gear, or overdrive, and even after we have had 1st for a while we are constantly loosing it while 4wdriving..Please Help Its Driving me mad!! :crazy:
Vehicle: Serria
Post Posted: Sun Dec 11, 2011 6:13 am
Buy a Serria and put the motor in it and bolt the 5 speed up to it. Way better car then those vitara hairdresser cars. Lol.
Sj80 cab on sj70 chassis 5inch lift 1.6 turbo inte
Post Posted: Sun Dec 11, 2011 6:52 am
Have you checked the fluid levels? Does it smell burnt?
2002 SWB GV
Lifted and Locked
Post Posted: Sun Dec 11, 2011 9:20 am
As stated, check fluid level first. Next step then should probably be a fluid and filter change.
Post Posted: Sun Dec 11, 2011 9:30 am
X2.....
Talking to you today, that's the 2nd time you've run it out of fluid, auto's don't like that & need to be "run through" to get the fluid level correct.....
Or you could just ban your BF from driving it... :lol:
Post Posted: Tue Dec 13, 2011 6:43 am
its not the fluids.. we have played with the fluid levels and its had brand new fluids put in it twice in last 2months.. we have had the transmission flushes... worked a little smoother for a bit then went back to shit..
Post Posted: Tue Dec 13, 2011 6:45 am
the boyfriend is a better driver then i am...
Post Posted: Tue Dec 13, 2011 6:59 am
Have you taken the pan off? The pick-up may be full of shit? I haven't had a pan off one of these ones before but the pick-up is usually also a changeable filter
Post Posted: Tue Dec 13, 2011 7:48 am
Run the trouble codes for the auto? 2-3 only is "limp home" IIRC.
Users browsing this forum: No registered users and 130 guests
