It is currently Thu Oct 01, 2026 1:25 pm
Post Posted: Tue Oct 06, 2009 1:22 am
Im having major issues putting my front end back together.
I have tried 2 different knuckles, 4 different kingpin bearings and cannot get the stub axle to line up with the axle tube. No amount of shimming will even get it close, its out by around 5mm.
Is this because of a bent housing? The housing looks fine against a straight edge, do they bend right at the knuckle? Or am i missing something else.
Post Posted: Tue Oct 06, 2009 1:39 am
Even if the housing IS bent, the knuckle should line up as the kingpins are right on the outer edge.
Are the Kingping bearing cones fully seated in the housing? No crap stopping them from fully seating?
And you haven't done something real :oops!: like putting the opposite side knuckle on upside down?
Post Posted: Tue Oct 06, 2009 1:46 am
cones are seated and i am using the right knuckle.
that was the first thing i checked haha
Post Posted: Tue Oct 06, 2009 2:05 am
Can you put more pic`s up? Hard to see of that 1
Post Posted: Tue Oct 06, 2009 8:53 am
so are you saying that there is a 5mm gap between the swivel hub and knuckle?
Post Posted: Tue Oct 06, 2009 1:10 pm
You want me to come and have a look?
I'll bring those parts too.
Post Posted: Tue Oct 06, 2009 7:16 pm
I wont be working on the car til thursday arvo, ill give you a call then jas cheers.
Users browsing this forum: Google [Bot] and 98 guests
