It is currently Sat Oct 03, 2026 5:27 pm
Post Posted: Thu Oct 08, 2009 12:50 am
As some people might know i have a toyota 5k motor in my lwb sierra. I have been tryig to remove one of the hydraulic lifters to replace it as its buggered but for the life of me cant work out how it comes out.
does anyone have an idea how to remove them?
cheers
Post Posted: Thu Oct 08, 2009 12:55 am
Make a fake name and pretend to be a toyota freeek and get on a toyota forum and ask....
Post Posted: Thu Oct 08, 2009 12:58 am
I was just hoping somone on here might no how to remove one thought that it may be a universal thing
Post Posted: Thu Oct 08, 2009 12:59 am
Post up a pic, can't be that hard
Post Posted: Thu Oct 08, 2009 1:02 am
Oooo, fun, ever used a slide hammer? same theory, cam lobe on a closed cycle so the lifter is down, either hook the lifter with something stong or if room allow`s, grag the top rim with pointy vice grip`s & pull up, push down & repeat till it come`s, if it dosen`t come the cam will have to come out & taped out from the bottem.
Sometime`s the base of the lifter will flare out making it almost imposable to remove them..
Have fun...
Hope that help`s.
Post Posted: Thu Oct 08, 2009 1:09 am
this is the best i could do
Post Posted: Thu Oct 08, 2009 1:23 am
Yep that`s them..
Post Posted: Thu Oct 08, 2009 1:33 am
pulled the lifters out of my bosses toyota 12ht motor. gotta use a telescopic pole with a magnet on the end, like 5 bucks from bunnings. works a treat. hope this helps.
Post Posted: Thu Oct 08, 2009 1:36 am
so steknig just pull it up and down untill it comes out i can get hold of it with pliers but it must be burred like mentioned
Post Posted: Thu Oct 08, 2009 1:38 am
Yep, Keep going, some time`s you get lucky & thay come easy, just keep working it. If it`s only a small lip on the bottom it should come out ok..
Post Posted: Thu Oct 08, 2009 1:49 am
ok will persist with it thanks for the help mate
Post Posted: Thu Oct 08, 2009 1:50 am
No prob`s, hope it come`s from the top for ya.
Post Posted: Thu Oct 08, 2009 2:12 am
well i was out there for 15 minutes pulling on it and it hasn't budged ill go buy a pair of pointy nose vice grips tomorrow and give that a go.
Post Posted: Thu Oct 08, 2009 11:50 am
The best way to get the suckers out is with a "Lifter Puller".
Post Posted: Thu Oct 08, 2009 3:39 pm
Agreed, get one of them if you can......
Users browsing this forum: No registered users and 145 guests
