It is currently Sat Oct 03, 2026 7:04 pm
Vehicle: lj81 stockman
Post Posted: Thu Oct 08, 2009 3:35 pm
going to get some longer leaf springs made cause i dont want to look around 4 some. How much longer do i need to get them, i have 2 inch lift 2 inch shackels its 4 the rear to
the wobble rocks
Post Posted: Thu Oct 08, 2009 3:59 pm
mine were 100mm longer with the pin in the same spot relative to the front and I am sure 230mm camber measured as having the spring sitting upside down on the ground from ground to where the diff would sit
to work it out I measured a flat line from the front mount to the point where the spring eye would be with the shackle at a 45 degree angle
Post Posted: Thu Oct 08, 2009 4:57 pm
so if i got from the pin to the back made 2 inch longer but keep from the pin to the front the same i should get a better shackle angle ???
the wobble rocks
Post Posted: Thu Oct 08, 2009 5:06 pm
Yes, Have a look, grab a ruler and see what the shackle should do with the spring 2" longer.
You may also drop the height in the rear because of the new angle if you get the same arch/spring rate.
P.s. Your sig doesnt make sense. Is it meant to be spelt quiet? as in shhhhh?
Post Posted: Thu Oct 08, 2009 6:52 pm
thanks and yes dident notice that
the wobble rocks
Users browsing this forum: Google Adsense [Bot] and 143 guests
