It is currently Wed Oct 07, 2026 7:22 pm
Post Posted: Sun Oct 11, 2009 5:09 pm
is it bad to fit the power,earth and aerial string together in corrugated tubing?
Vehicle: SV420
Post Posted: Sun Oct 11, 2009 5:24 pm
Better then them flopping loosely around the joint where they can get damaged :)
Post Posted: Sun Oct 11, 2009 5:27 pm
no problems there... just dont twist the cables around one another as this may cuase impedance.
Post Posted: Sun Oct 11, 2009 5:53 pm
excellent :D thanks mate
Vehicle: SV420
Post Posted: Sun Oct 11, 2009 8:08 pm
If you were running AC power cable - domestic 240v 50 Hz then you would want to keep AV cable a foot away. I think they are the rules for that stuff - I just work with computers so don't know much about cars :)
Post Posted: Sun Oct 11, 2009 9:07 pm
ok...personally i wouldnt do it...as u CAN still get noise that way.....i try to keep all power cables away from co-ax and low signal cables.....i have seen it happen quite a few times......cust comes in after installing his own radio and asks us why he is getting engine noise coming from his uhf.....and he usually had the power and coax running together
333...................im only half evil
Post Posted: Sun Oct 11, 2009 10:16 pm
the aerial string wasn't long enough to put the aerial where i wanted it and the
new possie means that all the string's go in different directions. so all good now. :D
Vehicle: MY2019 Jimny
Post Posted: Sun Oct 11, 2009 11:25 pm
It will be ok Shep -
Users browsing this forum: Google [Bot] and 197 guests
