It is currently Thu Oct 08, 2026 1:19 am
Post Posted: Sun Oct 11, 2009 8:20 pm
I have done the 1.6 transplant into my sierra and I have already shaved the starter to fit. the trans is on with the plate and i have the starter on but I have misplaced the 2 top trans bolts. my addaptor plate is 5mm thick and the original plate is about 1 mm.
The question I have it with me loosing the 2 bolts and the trans already on without having to take it off again does anyone know the thread/size bolt I need to replace them with.
((damn 1st yr apprentice cleaning up tosses out everything))
Post Posted: Sun Oct 11, 2009 8:45 pm
M8 X 1.25
Post Posted: Sun Oct 11, 2009 8:56 pm
how long
Post Posted: Sun Oct 11, 2009 9:14 pm
get a vernieer and use the depth guage
Post Posted: Sun Oct 11, 2009 9:49 pm
25-30mm.
Aren't you a mechanic Dave?
Post Posted: Sun Oct 11, 2009 10:18 pm
I am reaiong this as the bolts between the box and the block up the top? unless I am missing something with the adaptor they use the vit bolts which are M14 something
Post Posted: Sun Oct 11, 2009 11:08 pm
Not just any old mechanic....
v.w.dave wrote:
I am a master VW Tech (11yrs)
Post Posted: Sun Oct 11, 2009 11:15 pm
Yes want33 I am a mechanic. But I am a lazy one and that is the reason I became a service manager.
I dont want to pull the box back off to figure it out. I wanted to stop by the shop on the way to work on monday and just get them. Not go to work pull the box back off take a thread reading then figure out the length then leave work again to go back to the shop I passed on the way to work to get the 2 bolts I needed to finish a job.
I pulled the box on thursday after noon and I found that my apprentice accedently cleaned up about 6 of my bolts friday morning. but I didnt realise this till sat morning when I was putting the box back in.
SO I put the simple question up to save me the time.
Now Want33s would that make me a Bad mechanic or a smart one trying to save time????? Ohh and to add to the chime in's ScrawnC I have been a VW mechanic for wayyyy to long. I never once said I know anything about Zooks. I have often said I dont know them that well and that I was new to the zook world.
Post Posted: Sun Oct 11, 2009 11:22 pm
a bad one if you didn't kick the living shit out of you apprentice :thefinger:
are you sure your not that apprentice :wink:
Post Posted: Sun Oct 11, 2009 11:44 pm
Naaahhh he is fairly good I wouldnt do that. I am a good boss :) I left them off to the side he was just doing his job.
But yes I am the trainee on zooks
Post Posted: Mon Oct 12, 2009 12:23 am
Yeah no worries Dave don't thank me or anyone else for answers to your questions. :roll:
Makes perfect sense now.
A good mechanic would remember the size of the bolts removed.
What is wrong with finding a few bolts that are around the shop and trying them to work out what the thread/length is?
Glad I don't own a VW. :roll:
Jas.
Post Posted: Mon Oct 12, 2009 12:43 am
VW = Imperial, good luck making them fit
Post Posted: Mon Oct 12, 2009 5:04 am
Want33s I did just that I have buckets of old bolts that I tried but nun were the right size the only ones I had that were long enough were old head bolts but they were too thin.
I often thank people and if you knew me you would know I give way more then I ever get. I am a very thankfull person but when a simple question is made as a mockery (thanks wants33 and ScrawnC) I see no reason to thank you.
HAHAHAH and your glad you dont have a VW dude get a life hahaha you probably couldnt afford one seeing as your still wanting 33s hahah big jokes haha dork...
Oh and thank you royce for giving a simple answer to a simple question.
and ajsr I would normaly use my vernieer and use the depth guage but as I said I already have the box on the motor and didnt want to have to pull it off to get the size
Post Posted: Mon Oct 12, 2009 11:33 am
1.3 block top bolts are m10 x 1.25, 1.6 top bolts are m12 x 1.25.
Post Posted: Mon Oct 12, 2009 11:54 am
So you already know the depth of the hole by using a smaller diameter bolt.
My apologies for misreading the initial question. I thought you wanted starter bolt sizes...Where in "M8 X 1.25" is there any mockery?
Name calling.... Very mature... :roll:
See top.
Post Posted: Mon Oct 12, 2009 12:19 pm
Thanks want33s, That is all I was asking for. Yes I did know about how long they needed to be. But see if it wasn't obvious I was at home the zook was at my work. As I explained I wanted to pick up the new bolts on the way to work to save the time of having to run back and forth. That is why I was asking to save me the trouble. I knew M8 was way to small and after reading it I knew that was for the starter.
Thank you for your help in the end.
Post Posted: Mon Oct 12, 2009 9:25 pm
12/1.25/80mm just so we all know next time.....
Post Posted: Mon Oct 12, 2009 11:29 pm
relax boys or we will have to get the glove's out :no:
 Profile YIM
Users browsing this forum: No registered users and 291 guests
