It is currently Thu Oct 08, 2026 7:26 pm
Post Posted: Sun Oct 11, 2009 9:36 pm
Hi All,
Doing a full oil change on difs, t'fer and box tomorrow. I found a Nulon 85W/140 oil, too heavy or ok? Or should I just go with old faithful castrol VMX80?
I know this has been posted a million times B4, couldn't find it and I wanted to know what you all think of the Nulon oil?
Rusho
Post Posted: Sun Oct 11, 2009 9:53 pm
Vmx80 can`t be used in diff`s, It`s a gear box only oil, 140 is a bit heavy, 80w90 is fine, nulon good.......
Post Posted: Sun Oct 11, 2009 9:55 pm
Tried 85w/140 in mine cos that's what we had at work, waaaay too heavy!!! :lol: The car barely moved the next morning
Post Posted: Sun Oct 11, 2009 10:06 pm
That`s strange, cause that`s normally the best stuff, I use work`s all the time.... :roll:
Post Posted: Sun Oct 11, 2009 10:13 pm
I just ended up using 75w90 in all :roll:
Post Posted: Sun Oct 11, 2009 10:17 pm
i run 3/4 90/140 and a quarter moreys in the diffs
and 50% moreys and 50% 90/40 in the transfer
I wouldn't use either in the gearbox ,they are too heavy
the reason I use the others is for the shock loading particulary in the transfer. And its not an on road car so performance/ economy is not an issue.
but any diff oil around 90w is fine in your gearbox or diff,they are not race cars.
you would be better putting cheap diff oil in and changing it twice as often.
Users browsing this forum: No registered users and 191 guests
