http://auszookers.com/forum/
Gear shift removal help.....
http://auszookers.com/forum/viewtopic.php?f=5&t=7178
Author:  smally1.6 [ Mon Oct 12, 2009 11:36 pm ]
Post subject:  Gear shift removal help.....
G/day all.
We put a bodylift in my Vitara during the weekend(post some photos soon :D ).
I trimmed some body work around both gear shifts but it is still not quite right :cry: I still want to keep my console fitted, so i have decided to remove both gearshifts & bend them so they are not binding up around the body & rubber boots...
I do need some advice help on how to remove both gear shifts..
do i just remove the 2x 12mmbolts each side of the shifts & pull these out...
Do i have to look out for anything on removing these.(springs/clips etc)
Is it easy to refit....
Here is a photo of the main gear shift.
And here is the transfer gear shift...
Can i just bend these or do i have to heat these up first :?:
thanks smally
Author:  michael [ Tue Oct 13, 2009 12:14 am ]
Post subject:  Re: Gear shift removal help.....
Umm...I don't have a clue, but I think the gear sticks have rubber inside them to dampen vibration. If you heat that up it will probably burn. I could be wrong, but I thought I'd mention just in case...
(my old Poohjero had rubber in the levers)
Michael
Author:  Built4thrashing [ Tue Oct 13, 2009 12:26 am ]
push down and twist the metal cap inside the gearbox the shifter goes through. can be a PITA first time around.
Author:  alex [ Tue Oct 13, 2009 12:28 am ]
x2 getting it back on is easer :)
Author:  Taff [ Tue Oct 13, 2009 12:30 am ]
its alot easier to do from underneath imo
Author:  steak_knife [ Tue Oct 13, 2009 1:39 am ]
X3, gettin the apprentice to do it is even easier.... :roll:
Author:  alex [ Tue Oct 13, 2009 1:40 am ]
i no im an apprentice :roll:
Author:  Junior_91 [ Tue Oct 13, 2009 3:10 am ]
Me too :roll:
Author:  steak_knife [ Tue Oct 13, 2009 9:13 pm ]
Junior_91 wrote:
Me too :roll:
I`m not!!!!! :P
