It is currently Thu Oct 08, 2026 9:13 am
Post Posted: Wed Oct 14, 2009 1:20 pm
Apparantly Suzuki heads are a bit of a PITA to work on compared to some other vehicles!
I'm in the market for a valve spring compressor, what's going to work for me?
Steknig, here's your chance to make a post with some meaningful tech content for once :mrgreen: :lol:
Post Posted: Wed Oct 14, 2009 1:32 pm
What about this one Damo?
Post Posted: Wed Oct 14, 2009 2:21 pm
the issue is that to get the valves out, you need to remove the springs, then get the cam out... it will cost about $60 to get the valves out of a head if you get a shop to do it.... but they will do it right and once...lol
Post Posted: Wed Oct 14, 2009 2:28 pm
I cant see the link but I have removed the springs on an 8 valve head before whilst still on the car and the cam and rocker gear still fitted with a generic overhead compressor before
16v are harder though, I used a normal on bench lever one with some pipes of pipe and a magnet I think
Post Posted: Wed Oct 14, 2009 2:33 pm
I agree with what you're saying about the 16v one. I might have another look at the head tonight and see if the sort of compressor that Scrawn mentioned would work. I may just have to make something up like that bench mounted thing, I am sure I have seen pics of one of those before.
The problem is next time I want to pull a head apart it's another $60. Not to mention running back and forward to the machine shop. It's an opportunity to buy tools man! Do you not get it!!!??? :lol:
Post Posted: Wed Oct 14, 2009 3:06 pm
Getting the springs off is the easy part. No special tools needed. A spark plug socket and a big copper hammer takes care of it. 8)
Getting it back together is a bit more complex :wink:
Post Posted: Wed Oct 14, 2009 5:17 pm
i am a tool so i need to buy nothing... :lol:
Post Posted: Wed Oct 14, 2009 9:54 pm
Won`t work, you need http://www.sears.com/shc/s/ProductDispl ... alogId=126
This style but with a smaller cap end, thay only lil bugger`s
Post Posted: Wed Oct 14, 2009 9:55 pm
pompoms pompoms pompoms
Post Posted: Wed Oct 14, 2009 10:10 pm
link no worky :(
Post Posted: Wed Oct 14, 2009 10:22 pm
http://www.sears.com/shc/s/search_10153 ... &x=14&y=14
try that..
Post Posted: Wed Oct 14, 2009 10:38 pm
steknig wrote:
http://www.sears.com/shc/s/search_10153_12605?keyword=valve+spring+compressours&x=14&y=14
try that..
Any idea where i'd get one of those over here?
Post Posted: Wed Oct 14, 2009 10:46 pm
I`ve always given my head`s to a head shop, I have a tool like thi one scrawn put a link up for if you want to try it.
If you have a steel bench, weld an upright of around 40cm, bolt a pipe to that so it can be used as a leaver & cut out a section of yet another piece so you can get the collett`s out/in & have that on the leaver, If you know what I mean... can picture it, but when I read it :?
i need sleep.
Post Posted: Wed Oct 14, 2009 10:48 pm
steknig wrote:
i need sleep.
Get off the internet then!!
Post Posted: Wed Oct 14, 2009 10:53 pm
ScrawnC wrote:
steknig wrote:
i need sleep.
But then I couln`t talk to the like`s of you honey!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
:finger: :finger: :finger: :finger:
Users browsing this forum: No registered users and 194 guests
