| Disconnecting Sway Bar http://auszookers.com/forum/viewtopic.php?f=5&t=7221 |
| Author: | thompson_2986 [ Wed Oct 14, 2009 5:04 pm ] |
| Post subject: | Disconnecting Sway Bar |
Im looking for a way to make my sway bar disconnecting, so that when going off-road I can basically pull a pin and it’s done. If people have already fab up a design, could they please posts pics Cheers Tom |
| Author: | 31zook [ Wed Oct 14, 2009 5:13 pm ] |
| Post subject: | Re: Disconnecting Sway Bar |
i've never made one but if there is a market i can... sway bars on leafies make no difference anyway... |
| Author: | gregt [ Wed Oct 14, 2009 8:24 pm ] |
dissconnect it with a spanner then throw it in the back of the shed |
| Author: | Joe [ Wed Oct 14, 2009 9:46 pm ] |
gregt wrote: dissconnect it with a spanner then throw it in the back of the shed
x2 |
| Author: | steak_knife [ Wed Oct 14, 2009 10:21 pm ] |
joseph wrote: gregt wrote: dissconnect it with a spanner then throw it in the back of the shed x2 X3 |
| Author: | bron5on [ Thu Oct 15, 2009 6:56 pm ] |
steknig wrote: joseph wrote: gregt wrote: dissconnect it with a spanner then throw it in the back of the shed x2 X3 Yeah, why not. X4 |
| Author: | Scrawny [ Thu Oct 15, 2009 9:50 pm ] |
I gotta put mine back on so I can get the body lift certified. If there was an easy solution for disconnecting it I would happily run it on the road. |
| Author: | zukenutter [ Fri Oct 16, 2009 2:56 am ] |
I can't remember how the sway bar mounts to the chassis on a Sierra. I used to run mine without it too. My Jimny is a bit sloppier around corners without the sway bar compared to a Sierra. I set up a hanger so I only have to unbolt it from the chassis. It hangs in the centre using a rubber exhaust hanger. It works quite well |
| Author: | steak_knife [ Fri Oct 16, 2009 3:12 am ] |
Must be noisy, good think`n tho... |
| Author: | zukenutter [ Fri Oct 16, 2009 12:09 pm ] |
steknig wrote: Must be noisy, good think`n tho...
The square tube comes out when I unbolt it and the hanger suspends it about 50mm from the chassis. It only makes contact when flexed> I can live with the odd clunk |
| Author: | steak_knife [ Fri Oct 16, 2009 10:41 pm ] |
zukenutter wrote: steknig wrote: Must be noisy, good think`n tho... The square tube comes out when I unbolt it and the hanger suspends it about 50mm from the chassis. It only makes contact when flexed> I can live with the odd clunk lucky, cause your car an`t gunna get any quieter. My car`s got lot`s of moan`s & groan`s of road, the door light even come`s on when a wheel is cocked. |
| Author: | zukenutter [ Fri Oct 16, 2009 10:57 pm ] |
Springs re-seating still make me nervous ... sometimes. |
| Author: | steak_knife [ Fri Oct 16, 2009 10:59 pm ] |
zukenutter wrote: Springs re-seating still make me nervous ... sometimes.
