It is currently Thu Oct 08, 2026 1:51 pm
Post Posted: Wed Oct 14, 2009 7:42 pm
g'day
i need to bend my gear shifter forward due to me and my dad installing a
bodylift. we were thinking cutting a wedge out of the back and then bending it and welding where the cut was so we need to know if it is steel or something like cast iron?
So does anyone know what the shifter is made from??
thanks
Post Posted: Wed Oct 14, 2009 7:53 pm
its steel mate well the bottom half is the as you move up theres rubber in there somewhere as it changes to a larger diameter.
cut it cool it in water,weld it cool it again in water...
i cut and welded a peice of pipe the size of my body lift if that helps,instead of the cut and bend approach..
Post Posted: Wed Oct 14, 2009 7:58 pm
thanks
Post Posted: Wed Oct 14, 2009 8:01 pm
Hey Smally,
I bent my gear lever in a vice so it's shaped like one of those 1980's layback BMX seat poles, it's got a double bend in it & my transfer case lever was extended 3" I had to trim some of the rubber bits to stop it knocking out of gear...
The shifter does end up being a fair bit shorter, I have a SAAS leather gear shift boot as the original one needed the "neck" to be cut off completely.
Post Posted: Wed Oct 14, 2009 8:15 pm
Thanks Atari4x4
i will extend both shifts by 2inch using pipe
cheers smally
Post Posted: Wed Oct 14, 2009 9:03 pm
Hey Smally,
Hey that's a funny lookin shift patten :thefinger: pompoms
Post Posted: Wed Oct 14, 2009 9:13 pm
it's a "reverse 5 speed H patter".... designed for left handed people :?
Users browsing this forum: No registered users and 109 guests
