It is currently Thu Oct 08, 2026 7:43 am
Post Posted: Wed Oct 14, 2009 10:17 pm
Hi All,
I have done a swivel hub rebuild(thanks scrawny for your advice). I am 99% sure that I have put the hub back correctly. It turns back and forth nice and freely. Is there any kind of test I can do to make sure?
Locking hub...sorry should have been a bit clearer.
Rusho
Post Posted: Wed Oct 14, 2009 10:29 pm
Go for a drive :D
Seriously though, have your Transfer in 2WD. Lock both hubs in, crawl underneath and turn your front drive shaft by hand. It may take nearly a full turn for it all to lock in, but once it does, you shouldn't be able to turn the shaft anymore.
If you can keep turning it, then either one or both your hubs aren't working properly.
Post Posted: Wed Oct 14, 2009 10:52 pm
Trojan wrote:
Go for a drive :D
he mean`s swivel hub`s. put a wheel on , grab top & bottom of said wheel & wobble, ( the wheel, not your ass) If there is no movement & no tight spot`s when going from lock to lock you have done well.. pompoms yess!!
Post Posted: Wed Oct 14, 2009 10:59 pm
Sorry steknig...did mean locking hub..cheers. While I have your mind ticking about movement in wheels. Bearing, full hub rebuild, positive that everything is tightened up correctly. It has the same movement in it before i did the swivel hub rebuild. Any ideas??
Post Posted: Wed Oct 14, 2009 11:02 pm
up & down? Did you shim it , the king pin bearing`s that is, or swivel bearing`s. :roll: Are the wheel bearing`s tight?
Post Posted: Wed Oct 14, 2009 11:16 pm
I put the same shims back in..how do i tell if i need more shimming, and where can i purchase such shims? I can't get the wheel bearing any tighter without making the wheel spinning freely without restriction if that makes sense
Vehicle: 96 LWB Vit, 2.5L powerhouse
Post Posted: Wed Oct 14, 2009 11:31 pm
hey mate, does it have a slight wobble when you grab the wheel at the top and push in and out? I might not be grasping the issue of this thread but could be the same as the issue im having. ??? let me know.
1997 Sierra, daily driver, 60mm coils, 2 inch body
Post Posted: Wed Oct 14, 2009 11:46 pm
Just jacked the front up, I hate trying to explain things! It feels like the wheel is not doing up enough, its the kind of movement you could expect if you undid the nuts a poof-tinth. Fucked if i know anymore. I might take it to someone who cares/knows.
Post Posted: Wed Oct 14, 2009 11:51 pm
I do both but it`s imposable to fix on a key board, you need to get some one to wobble it while you are under the front & watch the swivel hub & knuckle to see if there is any movement, if there is it the shim`s on the king pin, If movement is there, take the smallest shim out & try again...
Post Posted: Thu Oct 15, 2009 12:03 am
Where could i find such a person steknig??? :wink: :wink:
Post Posted: Thu Oct 15, 2009 12:05 am
Check ya pm`s :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll: :roll:
Post Posted: Thu Oct 15, 2009 12:10 am
Probably should have done that before I did that last post. Cheers
Post Posted: Thu Oct 15, 2009 12:41 pm
Where do you live Adrian?
Users browsing this forum: Google [Bot] and 160 guests
