It is currently Thu Oct 08, 2026 2:54 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2  Next
Vehicle: 89 Softtop Sierra, 6.5's, 30's
Post Posted: Fri Oct 16, 2009 8:45 pm
Hey, just wondering if there were any key tips to changing the gearbox oil.
I have an 89 sierra if that makes any difference.
Post Posted: Fri Oct 16, 2009 8:50 pm
Put the drain plug in before filling back up.
Post Posted: Fri Oct 16, 2009 8:53 pm
Doh, is that why I have so much oil on my shed floor, bugga.
Post Posted: Fri Oct 16, 2009 8:58 pm
Ok let me elaborate, I haven't done it before and it looks awkward. I have no photo guides, and the shitty drawings in the car manual aren't exactly crystal clear. Do I need any specific tools like a funnel etc? Is there a process to it or anything specific?
Or is it simply drain and re-fill
Post Posted: Fri Oct 16, 2009 9:35 pm
It helps to take it for a drive first to warm up the oil - it drains a bit easier this way. Tke out the drain plus and the fill/level plug and let the oil drain out completely.
As mentioned above, its pretty important to replace the drain plug once its finished draining... ;)
Gearbox fill plugs can be awkward to pour oil into. Some sort of siphon pump is often handy, or do what I did last time and squirt it in from a (clean) dishwashing liquid bottle. Fill it just to the level of the plug.
Put the fill plug back in, then drive it away!
Post Posted: Fri Oct 16, 2009 9:38 pm
Just in case plan....undo the filler first. I always to this just in case you drain the oil and can't fill it up Its not a good look.
Post Posted: Fri Oct 16, 2009 9:41 pm
You will need a 3/8 drive rachet or a 10mm square drive to un-do the plugs. You will also need some kind of syringe or similar to get the oil back in. You can't just simply pour the oil back in.
Something like this is ideal
Post Posted: Fri Oct 16, 2009 9:46 pm
Hi sbyard,
sorry for the hijack, but I also wanted to ask the guys about this.
I did my diffs and T/Case and G/box last weekend and I found that the 3/8" square drive plugs are all chewed out.
Does anyone know of any replacement plugs for the Zook?
Cheers, Davo.
'94 sierra
Thank-you http://www.locktup4x4.com.
Post Posted: Fri Oct 16, 2009 9:48 pm
Thank you for your help. Please excuse my lack of knowledge.
Is there a separate oil fill spot for the low range section?
I think I may be looking at the wrong section of the car. How far down is the gear box fill point, if underneath the car?
Post Posted: Fri Oct 16, 2009 9:49 pm
kreecha wrote:
Hi sbyard,
Cheers, Davo.
Try and track down some new ones, either Suzuki genuine or second hand. They are easy to round out if they are too tight.
Post Posted: Fri Oct 16, 2009 10:03 pm
The transfer case and gearbox are seperate, if that is what you mean. The fill plug should be on the side of the gearbox, underneath the car.
Another point thats worth noting: gearbox oil stinks, so it pays not to make a mess while you are doing this.
Don't worry about the lack of knowledge, we all have to start somewhere.
Post Posted: Fri Oct 16, 2009 10:12 pm
ScrawnC wrote:
kreecha wrote:
Hi sbyard,
Cheers, Davo.
Shit so I gotta stick with them 10mm square drive jobbies? :(
Post Posted: Fri Oct 16, 2009 10:44 pm
The reason I was checking the oil is because the other day it was stuck in reverse, as the screw the gear stick pivots off had sheared. I replaced that, and it seems to be working, except that now its making a noise, that seems to be coming from the gearbox. Just checked the oil level in the box and its full.
So now I'm stumped as to what the noise is?
Any ideas?
Reckon I can drive on it?
Post Posted: Fri Oct 16, 2009 11:24 pm
kreecha wrote:
ScrawnC wrote:
kreecha wrote:
Hi sbyard,
Cheers, Davo.
You can weld a nut of your choice to them :wink:
Post Posted: Fri Oct 16, 2009 11:44 pm
Any ideas?
Where did the sheared off bit go?
Post Posted: Fri Oct 16, 2009 11:55 pm
Any ideas?
Couldnt find it. I may have cleaned it out.
I think the noise is coming from the clutch plate. Cause like I said, the noise only happens when clutch is out. I also havnt put the cover back on, so there nothing insulating the noise.....
Post Posted: Fri Oct 16, 2009 11:56 pm
So maybe clutch release bearing or input shaft bearing. Change oil as planned and see what happens
Post Posted: Fri Oct 16, 2009 11:59 pm
If it is that, can I still drive on it?
Post Posted: Sat Oct 17, 2009 12:01 am
Yep, if that's the problem
Post Posted: Wed Oct 21, 2009 9:37 pm
Post Posted: Wed Oct 21, 2009 9:59 pm
That`s what i thort to. :? :lol:
Post Posted: Wed Oct 21, 2009 10:08 pm
you did not, you just wanted to add another post, hehe.
Post Posted: Wed Oct 21, 2009 10:30 pm
Yes, But I fail to see the problem.
Post Posted: Wed Oct 21, 2009 10:37 pm
kreecha wrote:
ScrawnC wrote:
kreecha wrote:
Hi sbyard,
Cheers, Davo.
There really isn't anything wrong with the square drive ones, when you use a 10mm square drive socket. It's a worthwhile investment to get one.
Post Posted: Wed Oct 21, 2009 10:45 pm
heheheheheheheeeee recon, sorry
Post Posted: Wed Oct 21, 2009 11:17 pm
What for? Most people would of just called me a post whore for some unknown reason :roll: :? 8O
Vehicle: 1995 Sierra 1.3
Post Posted: Fri Dec 24, 2010 2:11 pm
Vehicle: LPG 1.6 Sierra
Post Posted: Fri Dec 24, 2010 2:17 pm
I used my socket wrench. Didn't damage the plug, worked a treat
Post Posted: Fri Dec 24, 2010 8:32 pm
^^ Don't I run the risk of damaging the drain and fill plugs using 3/8 socket wrench?
Oh and Merry Christmas :)
Post Posted: Fri Dec 24, 2010 8:53 pm
http://cgi.ebay.com/ebaymotors/8-10mm-S ... 0581621803
Tis the only one's I could find..
I use 3/8th, yes you run a risk but most time's you'll get em out, depends on how tight they have been done up..
Users browsing this forum: Google [Bot] and 187 guests
