| dramas fitting new fuel pump http://auszookers.com/forum/viewtopic.php?f=5&t=7278 |
| Author: | ZookiDave [ Fri Oct 16, 2009 11:38 pm ] |
| Post subject: | dramas fitting new fuel pump |
hey, can anyone offer any advice on how i can get the new fuel pump to fit in my 95 sierra 1.3 carb, it is identical to the original but it just wont go in far enough. is there a trick to this or just real fiddly please respond asap cheers ZUKPWR |
| Author: | Rusho [ Fri Oct 16, 2009 11:58 pm ] |
| Post subject: | Re: dramas fitting new fuel pump |
Trick..kinda. Just for the record I suck at explaining shit. This is what I did anyway. Turn your engine over by hand so the shaft comes out just past the block, place the pump over the shaft and make sure the rocker arm is touching it and inline with it. Start the bolts a few turns. Do up bolts from side to side evenly tensioning as you go until its fully done up. Hope that helps and is not as clear as mud. Enjoy |
| Author: | steak_knife [ Fri Oct 16, 2009 11:59 pm ] |
ZookiDave wrote: hey, can anyone offer any advice on how i can get the new fuel pump to fit in my 95 sierra 1.3 carb, it is identical to the original but it just wont go in far enough. is there a trick to this or just real fiddly
please respond asap cheers ZUKPWR Wind the eng over by hand, make sure the ing is OFF, grab the fan blade`s as close to the pulley as you can & turn it to the passenger side, also check that the insulator is not still on the old pump. Wind in the eng over is just getting the pump lobe of the cam to a different pos.... |
| Author: | steak_knife [ Sat Oct 17, 2009 12:00 am ] |
Rusho81 wrote: Trick..kinda. Just for the record I suck at explaining shit. This is what I did anyway. Turn your engine over by hand so the shaft comes out just past the block, place the pump over the shaft and make sure the rocker arm is touching it and inline with it. Start the bolts a few turns. Do up bolts from side to side evenly tensioning as you go until its fully done up. Hope that helps and is not as clear as mud. Enjoy
You beat me to it. |
| Author: | ZookiDave [ Sat Oct 17, 2009 12:30 am ] |
thanks heap, worked a treat |
| Author: | steak_knife [ Sat Oct 17, 2009 12:32 am ] |
ZookiDave wrote: thanks heap, worked a treat
Me or Rusho? |
| Author: | Bruce [ Sat Oct 17, 2009 1:42 am ] |
It's all about u hey Post whore skeknig. |
| Author: | steak_knife [ Sat Oct 17, 2009 1:47 am ] |
Bruce wrote: It's all about u hey Post whore skeknig.
your point being? |
