It is currently Mon Oct 05, 2026 3:25 am
Post Posted: Sat Oct 17, 2009 10:28 pm
Hi All,
After todays wheel at the GH I really need to adjust my handbrake cable, so it actually does something. Pretty sure last time I attempted it I cracked the shits and didn't worry about it, I have new shoes in the back, so is it just as simple as adjusting them a bit more?
Thanks
Rusho
Vehicle: 75 Cruiser
Post Posted: Sat Oct 17, 2009 10:42 pm
Do your brakes work ok when using your foot on the brake? if so you don't need to adjust the rear shoes.
If your brake shoes are ok and adjusted properly , you can just adjust the handbrake cable which is right underneath the handbrake lever (under the car)
Post Posted: Sat Oct 17, 2009 10:43 pm
clean all the mud and gunk out and re adjust them. ive been meaning to do mine for along time too :oops:
Vehicle: 75 Cruiser
Post Posted: Sat Oct 17, 2009 10:47 pm
PS. if you have been through some mud , which i assume you have if you have been to GH, then you should pull your rear hubs off and clean out all the crap.
You may think your rear brakes work ok, but it's possible it's just your front brakes working.
If your rear brakes don't work, either shoes are worn or your brake cylinders are seized, it can get pretty dangerous. If you go up a steep hill and then stop and hit the brakes and only your front brakes work, you will go backwards real fast because front brakes don't do jack shit on a steep hill.
Post Posted: Sat Oct 17, 2009 10:51 pm
Pull the drums off Rusho, you will have a bit of mud in there from the water crossings we did. Then back the handbrake cable right off, adjust the rear brakes and then re-adjust the cable
Post Posted: Sat Oct 17, 2009 10:59 pm
Excellent...thanks guys. Thanks for my avatar pic to scrawny
Post Posted: Sun Oct 18, 2009 12:27 am
Scrawn did some thing good?? WTF???
:thefinger: peaceout :thefinger:
Post Posted: Sun Oct 18, 2009 12:29 am
The one and only time :roll: :roll: :roll: :roll:
Users browsing this forum: Google [Bot] and 212 guests
