It is currently Sat Oct 03, 2026 7:03 pm
Post Posted: Sun Oct 18, 2009 2:09 pm
Hi All,
im looking at putting in my 2" body lift today, ive done a bit of a search and it hasnt come up with anything.
what i need to know if, can i do the body lift, and get the brake lines extended down the line, say a few days?
or will the lines be to short and not fit after ive done the lift.
if all that is to confusing what im trying to say is i want to do the lift, and be able to drive to the brake place in town as i would like to leave the car with them so they get things right, dont have alot of confidence in some of the shops where i live
ive got a just_cruzin lift to
Ad's
Post Posted: Sun Oct 18, 2009 3:40 pm
If your not going off road, you should be fine, just make sure that you can turn lock to lock with out ANY tension on the line`s before going & the rear has no tension.
Post Posted: Sun Oct 18, 2009 3:42 pm
thanks mate,
i thought this would be the case, but better safe then sorry
Post Posted: Sun Oct 18, 2009 3:50 pm
make sure you check em. if thay a lil to short, leave the retainer`s out, SHORT term only. :wink:
Post Posted: Sun Oct 18, 2009 4:09 pm
When you do a body lift you don't have to extend any brake lines.
The ones near the booster. You can get away with just moding the bracket
Post Posted: Sun Oct 18, 2009 4:16 pm
x2. The instructions are pretty clear on what needs to be done.
Post Posted: Sun Oct 18, 2009 4:53 pm
What they said :D
Good choice in the kit Armsup
Vehicle: SJ80, SE416
Post Posted: Mon Oct 19, 2009 4:55 pm
If you own a coily, the front passenger side one need extending, as the line passes through a bush in the body, not chassis. You could dodge it up, but then again, that might be dangerous. $75 at somewhere like ABS should fix it.
Post Posted: Mon Oct 19, 2009 11:31 pm
just_cruizin wrote:
What they said :D
:roll: :roll: :lol: :lol:
Users browsing this forum: Google Adsense [Bot] and 152 guests
