hey guys i need a quick answer can the drum hand brake setup on a 86 drover transfer case be fitted to a sierra transfer case from a 92 model with rear cable handbrake. Might be scoring a wt wreck and want to rebuild the transfer case with gears and fit the transfer hand brake to put into the drover. cheers anton
Posted: Thu Nov 05, 2009 10:58 pm
pretty sure they do, output spline is the same, the driveshaft pcd is different but doesnt matter if you are putting back in the car the brake came frome
the mounting holes might not be tapped or the threads damaged, worth checking
Users browsing this forum: No registered users and 65 guests
