| radiator http://auszookers.com/forum/viewtopic.php?f=5&t=8040 |
| Author: | Brocbeau [ Tue Nov 17, 2009 11:38 pm ] |
| Post subject: | radiator |
pulled out my radiator today after driving and reilsiing something smelt a bit funny, radiator colours was green red and yellow? alos is it bad to mix fluids :S any way theirs a puncture through it pushing the little flairs through to one side, funnily enough it doenst leak except the botom brackets some how?? Sj413 95 Seirra WT radiator pleasee cheers boyyss |
| Author: | Shelby [ Wed Nov 18, 2009 12:13 am ] |
| Post subject: | Re: radiator |
just get it recored man im doin that too my 1lr radiator |
| Author: | Brocbeau [ Wed Nov 18, 2009 2:19 am ] |
Shelby wrote: just get it recored man im doin that too my 1lr radiator
id like a new well tidy old one..... might see what the wreckers can stitch me up for.. lol |
| Author: | hutch [ Wed Nov 18, 2009 2:45 am ] |
hi
| Author: | Brocbeau [ Wed Nov 18, 2009 2:56 am ] |
hutch wrote: hi
![]() hello hutch : D |
| Author: | Brocbeau [ Tue Nov 24, 2009 12:33 am ] |
delete this please |
| Author: | mnemonix [ Tue Nov 24, 2009 1:45 am ] |
I'm having a custom alloy radiator whipped up for my zook. Slightly larger than factory so new mounts will be required, and a themo fan with shroud will top it off. 500x500x56mm triple core. Bolt in replacement option might also be available. Will come in under $200 when they go retail in a couple of months. They'll be on ebay once they're available. |
| Author: | SuziBlu [ Tue Nov 24, 2009 7:44 pm ] |
mnemonix wrote: I'm having a custom alloy radiator whipped up for my zook.
Slightly larger than factory so new mounts will be required, and a themo fan with shroud will top it off. 500x500x56mm triple core. Bolt in replacement option might also be available. Will come in under $200 when they go retail in a couple of months. They'll be on ebay once they're available. Tell us more, Im very interested in one, my radiator is a bit hows ya mother. Holds the temp, but with summer coming, new needed. |
| Author: | mnemonix [ Tue Nov 24, 2009 8:39 pm ] |
Nothing much to tell other than what is above. I've had a few chats with a company that sells via ebay. They're Chinese based but from what i've seen their quality is definately up to scratch. I've got a few mates with turbo streeters using these radiators and can't fault them. A mates rb30/26 skyline making ~480kw at all fours runs one. That's good enough credentials for me. I'm getting mine made a bit oversized as the factory radiator can let the temp creep at times (on the beach) so a bit of extra volume and surface area won't go astray. Should know more in the next week or so. |
| Author: | kreecha [ Wed Nov 25, 2009 2:18 am ] |
mnemonix wrote: Nothing much to tell other than what is above.
I've had a few chats with a company that sells via ebay. They're Chinese based but from what i've seen their quality is definately up to scratch. I've got a few mates with turbo streeters using these radiators and can't fault them. A mates rb30/26 skyline making ~480kw at all fours runs one. That's good enough credentials for me. I'm getting mine made a bit oversized as the factory radiator can let the temp creep at times (on the beach) so a bit of extra volume and surface area won't go astray. Should know more in the next week or so. Sounds like what I heard at a 4BY shop in Sydney...... say Kings Park..... If they are one and the same then they will be awesome, and cheap 2! They are being designed for greater core thickness, larger liquid volume, and larger core surface area, all to bolt straight in. If these are the same ones did you also hear about the flash silicone rad hoses which will be available with them? Cheers, Davo. |
| Author: | mnemonix [ Wed Nov 25, 2009 2:22 am ] |
Don't think they're the same Davo. I only recently started talking to the manufacturer (a week ago) because I wanted them to make me a 1 off for my car. Then they made an offer of a great price if I could provide mounting details etc so they could do a production run. I'm all for more cheap performance products though. We all need a little extra for a little less |
| Author: | foonji [ Wed Nov 25, 2009 3:00 am ] |
Sounds good mnemonix |
| Author: | Damo [ Wed Nov 25, 2009 3:08 am ] |
kreecha wrote: mnemonix wrote: Nothing much to tell other than what is above. I've had a few chats with a company that sells via ebay. They're Chinese based but from what i've seen their quality is definately up to scratch. I've got a few mates with turbo streeters using these radiators and can't fault them. A mates rb30/26 skyline making ~480kw at all fours runs one. That's good enough credentials for me. I'm getting mine made a bit oversized as the factory radiator can let the temp creep at times (on the beach) so a bit of extra volume and surface area won't go astray. Should know more in the next week or so. Sounds like what I heard at a 4BY shop in Sydney...... say Kings Park..... If they are one and the same then they will be awesome, and cheap 2! They are being designed for greater core thickness, larger liquid volume, and larger core surface area, all to bolt straight in. If these are the same ones did you also hear about the flash silicone rad hoses which will be available with them? Cheers, Davo. More info on the rad hoses? I seem to eat through them for some reason. |
| Author: | Jamie [ Mon Dec 07, 2009 3:19 am ] |
mnemonix, do you know any more info on these radiators you are talking about? will be needing one soon, and cant find one that has aluminium tanks. would be very interested if it makes buying 2 cheaper for both of us. done the swift gti conversion into a 82 sierra. Cheers Jamie. another thought, brother in law races sprintcars, very close in sizing etc if you can get your hands on one, anyone let me know if they want some dimensions, reckon last time we bought one was $200 delivered. |
| Author: | mnemonix [ Mon Dec 07, 2009 4:02 am ] |
Cost me $175 delivered. 4-5 week build time. I'm 1 week into that period, so I should have a radiator on my doorstep in ~4 weeks worst case. |
| Author: | Fatzook [ Mon Dec 07, 2009 4:22 am ] |
I just bought one from Lowrange. $270 and 10 day lead time. Couldn't be stuffed waiting 2 months for the sake of $70. it is just a standard size, all alloy, but even at $270 its a bargain. So these $200 will be an absolute steel! |
| Author: | Jamie [ Mon Dec 07, 2009 10:48 pm ] |
have you got any info to get in contact with the company making the radiators, keen to get one ASAP. 175 is an awesome price |
