It is currently Sun Nov 15, 2026 3:48 am
Vehicle: MY2019 Jimny
Post Posted: Wed Mar 21, 2007 1:29 pm
Hey guys, me again...
I am going to replace the door linings, probably with alloy chequerplate but I wanted to hear of other options or problems, tips etc...
I can get the 2 doors, 2 rear panels and tailgate done for $200, is that a good price? I think it is about 3mm sheet...
Also, are the two doors identical? I only have one decent lining to use as a template...
What is the best way to fix the alloy sheet to the door? Screws, rivetts?
Thanks again!
Post Posted: Wed Mar 21, 2007 1:35 pm
yeah they are the same, pack some foam or something behind them though cause they wll rattle like crazy
Post Posted: Wed Mar 21, 2007 11:23 pm
I have wanted to this for a while! I priced up checker plate and you can only buy it in sheets and the cheapest qoute i got was about $120 from memory!
SO if thats all cut and ready to go then i would say go forit! 8)
back in a built sierra!
Post Posted: Thu Mar 22, 2007 1:07 am
I am actually thinking brushed alluminium sheet instead, chequer plate is a bit twee...
Post Posted: Thu Mar 22, 2007 1:26 am
I might get some door linings etc... to if you can get them made for that price let me know
Post Posted: Thu Mar 22, 2007 1:41 am
Where do you live rama? Ill work out some postage details if you like...
Post Posted: Thu Mar 22, 2007 1:33 pm
i live in redland bay queenlsland 4165
and will these skins have everything cut out ie door handles window winders etc...
Post Posted: Thu Mar 22, 2007 2:23 pm
They will be the same cutout as the doorskin I give the dude to copy. It is a skin to suit a 92 sierra... tell u what - Ill get mine done first, then if they are ok, Ill get you a set done.
Post Posted: Thu Mar 22, 2007 9:23 pm
when will you be doing it, as there might be two orders here down the track a little, mine is a 82 the other is a 85 i think they are the same skins though both of ours are lwb's so the backs will be longer.
Post Posted: Fri Mar 23, 2007 4:08 am
If you can send me a cardboard template, I can probably get them cut out...
All I can go on (and the metal dude) is the template I have.
If it is right, then the alloy lining will be right.
Post Posted: Fri Mar 23, 2007 1:46 pm
quote
are you saying you dont have any doors skins to work from, just the metal doors, if so i can copy mine onto carboard and send it down as well.
i have same spare ones in my shed i could copy from
Post Posted: Fri Mar 23, 2007 5:32 pm
I have a good door skin, and he can cut them to match exactly, incl all the cutouts...
If you can trace the rear skins onto cardboard and mail them, that would be better...
Post Posted: Mon Mar 26, 2007 9:31 pm
sorry to keep you hanging do you have any idea how much it would be to send up here, because with two cars worth postage may creep it up making it cheaper to find someone here, i'm going to do some ringing around this week, and see what i come up with price wise here.
At $200 its cheap cant argue with that there would be close to a hole sheet per car, shorely, and a sheet is around $120- $140 so at that he's charging around $70 labour I'd rather pay that, than do it myself.
I'll let you know what i come up with.
Post Posted: Sat Apr 28, 2007 9:17 pm
Im doing the same thing at work atm, but only to the 2 back panels and the tailgate... i can make it at work and get some leftr checker plate as well for it from there... Im not sure how im gunaix them on tho..i was thinking screws for easy removal.. + i was hoping to somhow use the area behind the back panels for some storage. i will hav to make my own template for the back right hand panel cause mine doesnt have one!
Once u have the materials its pretty easy to cut them out ect... especially if u have a template to go off!
Users browsing this forum: No registered users and 50 guests
