| front hubs - keeping the front hubs locked http://auszookers.com/forum/viewtopic.php?f=5&t=8289 |
| Author: | zooky08 [ Sun Nov 29, 2009 6:38 pm ] |
| Post subject: | front hubs - keeping the front hubs locked |
hey, just wondering does keeping the front hubs locked and driving around in 2wd, does that wreck your wheel bairings at all i might sound stupid, but i just started 4wding and i dont no every thing much preciated |
| Author: | Scrawny [ Sun Nov 29, 2009 6:39 pm ] |
| Post subject: | Re: front hubs |
No |
| Author: | shep [ Sun Nov 29, 2009 6:44 pm ] |
| Post subject: | Re: front hubs - keeping the front hubs locked |
just make sure it is in 2wd |
| Author: | lump_a_charcoal [ Sun Nov 29, 2009 7:05 pm ] |
It just uses more fuel by creating more drag. |
| Author: | zooky08 [ Sun Nov 29, 2009 7:20 pm ] |
ok thanks, i always drive around with the hubs locked, so it saves me times, from getting out of the car to lock them my car uses 6.7L to 100km so its pretty good on fuel |
| Author: | zookster666 [ Sun Nov 29, 2009 8:16 pm ] |
It does create more wear and tear in the long run which costs money seems pretty lazy no offence but it takes less than a minute to unlock the hubs. |
| Author: | zooky08 [ Sun Nov 29, 2009 8:38 pm ] |
i havnt been doing it for long maby couple of weeks its usualy my sis who gets in it ans goes down the paddock and locks the hubs and doesnt unlock them wen she finishes ill start unlocking them, because i dont want to warn them out and have to get new ones |
| Author: | royce [ Sun Nov 29, 2009 9:05 pm ] |
If you are just cruising around a paddock and going in and out of 4wd it would be ok, but if you were planning on going up the highway or a long drive on bitumen then it would be better to unlock them |
| Author: | IN2DEP [ Sun Nov 29, 2009 9:11 pm ] |
If thats your green zook on your pic, Looks good mate |
| Author: | zooky08 [ Sun Nov 29, 2009 10:10 pm ] |
yea well like i said my sis gets in it and lockes them then mum gets in it and takes it into town, but she only done it a couple of times driving into town with them locked in2dep..... yes that is my little beast thanks |
| Author: | Ben_Sierra [ Mon Nov 30, 2009 1:49 am ] |
When they are locked, the whole from drivetrain (axles, diffs, driveshift & the front output shaft on the transfer case) are spinning. Not a major drama, but it will cause extra wear and tear to all these components... |
| Author: | Damo [ Mon Nov 30, 2009 4:37 am ] |
Just say you locked your hubs and accidentally forgot about it. Then say because you don't go wheelin that often you haven't bothered to check your front diff oil level, and it's a bit low. So then you're driving around for a few months completely oblivious to the fact you have your hubs locked in. You're using a bit more fuel than usual but you probably aren't noticing that really. Then one morning you're driving to work at 3:50, and just as you pull off the motorway and start slowing down the bearings in the diff centre carrier finally sieze and your front tyres lock and you come to a screeching halt sideways in the middle of the road. Would that be enough reason to convince you not to run your zook on the road with the hubs locked in? Coz it farkin well was enough for me! |
| Author: | Joe [ Mon Nov 30, 2009 5:36 am ] |
Damo wrote: Just say you locked your hubs and accidentally forgot about it. Then say because you don't go wheelin that often you haven't bothered to check your front diff oil level, and it's a bit low. So then you're driving around for a few months completely oblivious to the fact you have your hubs locked in. You're using a bit more fuel than usual but you probably aren't noticing that really. Then one morning you're driving to work at 3:50, and just as you pull off the motorway and start slowing down the bearings in the diff centre carrier finally sieze and your front tyres lock and you come to a screeching halt sideways in the middle of the road. Would that be enough reason to convince you not to run your zook on the road with the hubs locked in?
| Author: | TASSIETOYUKI [ Mon Nov 30, 2009 3:20 pm ] |
Mine haven't been unlocked since April 2004, cant be bothered finding them in the cupboard and refitting them. I love my drive flanges... |
| Author: | SuziBlu [ Mon Nov 30, 2009 5:11 pm ] |
zooky08 wrote: ok thanks, i always drive around with the hubs locked, so it saves me times, from getting out of the car to lock them
my car uses 6.7L to 100km so its pretty good on fuel This seems almost unreal to me, are you sure its not 6.7k per litre. |
| Author: | Ben_Sierra [ Mon Nov 30, 2009 5:50 pm ] |
SuziBlu wrote: zooky08 wrote: ok thanks, i always drive around with the hubs locked, so it saves me times, from getting out of the car to lock them my car uses 6.7L to 100km so its pretty good on fuel This seems almost unreal to me, are you sure its not 6.7k per litre. Agreed. 6.7L/100km in a Sierra is impossible, unless its downhill all the way.... Old engine + Aerodynamics of a house brick. No way will it get 6.7. |
| Author: | SuziBlu [ Mon Nov 30, 2009 5:58 pm ] |
Yea many people bugger up the calculation. If you use 36 litres to travel 240k, that means you divide 36 by 240 to get 0.15 or 15 litres per hundred K. Many people divide 240 by 36 and get 6.66 kilometers per litre, which they confuse and think its 6.66 litres per hundred |
| Author: | Reubs [ Mon Nov 30, 2009 8:55 pm ] |
Ben_Sierra wrote: Agreed. 6.7L/100km in a Sierra is impossible, unless its downhill all the way.... Old engine + Aerodynamics of a house brick. No way will it get 6.7.
Unless it is an unloaded 1L Sierra on a low speed highway cruise! 8L/100 in a 1.3 isn't impossible either if driven "very nicely". |
| Author: | SuziBlu [ Mon Nov 30, 2009 9:20 pm ] |
Reubs wrote: Ben_Sierra wrote: Agreed. 6.7L/100km in a Sierra is impossible, unless its downhill all the way.... Old engine + Aerodynamics of a house brick. No way will it get 6.7. Unless it is an unloaded 1L Sierra on a low speed highway cruise! 8L/100 in a 1.3 isn't impossible either if driven "very nicely". Who the hell drives Miss Daisy in a suzi, lol doh |
| Author: | zooky08 [ Tue Dec 01, 2009 1:27 am ] |
Damo........I don't drive it on the rd with hubs locked only around the paddock some times. Longest it's been on the rd with hubs locked would be like 10 mins tops |
| Author: | zooky08 [ Tue Dec 01, 2009 1:34 am ] |
Well I just been told that wen I bought it I usually use the zook for a week on my property on empty and I never run out oh and I don't know what it does but I have a 1.3L with a 1.6 vitara head on it |
