http://auszookers.com/forum/
higher speed whine noise
http://auszookers.com/forum/viewtopic.php?f=5&t=8318
Author:  ninjadaniel [ Mon Nov 30, 2009 8:07 pm ]
Post subject:  higher speed whine noise
My Sierra has a whine that starts around 60km/h and is deafening at 110km/h, i wanted to know what is most commonly the cause, is it the transfer case or the gearbox & which parts would be the culpret. The car has only done 165,000kms and the gearbox shifts perfectly, id be surprised if this was the cause.
Cheers,
Daniel
Author:  boost=money [ Mon Nov 30, 2009 8:45 pm ]
Post subject:  Re: higher speed whine noise
check if there is oil in the diffs and gearbox transfer ect, check wheels bearings, and check tail shafts/jack shaft uni's
Author:  31zook [ Mon Nov 30, 2009 9:26 pm ]
when did you last change the oils?
Author:  ninjadaniel [ Tue Dec 01, 2009 1:04 am ]
cant remember tbh
Author:  TZAR [ Tue Dec 01, 2009 1:27 am ]
Thats normally the woman sitting next to you......
Or more likely it is the hardfacing has worn of some of the gears. Can be caused by corrosion OR incorrect oil.
Normally in the transfer case, best bet is to find one on here for $50 and slap it in.
Author:  steak_knife [ Tue Dec 01, 2009 1:52 am ]
Or Pm that steknig dick & see if he'll have a look for ya.
:P 8O
Author:  ninjadaniel [ Tue Dec 01, 2009 3:54 am ]
thanks for the comments guys, i'll keep an eye out for a transfer case!
Author:  Brocbeau [ Tue Dec 01, 2009 4:17 am ]
i had the same problem, but mine was solved by draning the water out of my diff :O!
PMSL!
