It is currently Sun Nov 15, 2026 5:54 am
Post Posted: Wed Dec 09, 2009 3:54 am
Okay so I was driving down to my motorcycle riding test on Sunday (it could have happened some other time - it cost me $161 plus I have to sit the L's test again 2 days off work etc. :evil: ) and suddenly lost all power.
After opening the bonnet my camshaft timing belt gear had managed to come forward over the bolt that holds it on. The center is all ground out!!
What would have caused this? The motor was out of a wreck and in the original accident the camshaft gear was broken. Is it possible that the camshaft was damaged/bent?
Has anyone heard of this happening before?
Post Posted: Wed Dec 09, 2009 3:56 am
was it the gear on the crank or on the cam?
Post Posted: Wed Dec 09, 2009 3:58 am
Cracked shaft...?
1990 SWB Vitara
1997 Sierra
1991 Sierra *RIP 7/0
Post Posted: Wed Dec 09, 2009 4:14 am
@jonno_racing: camshaft
@zacs7: possibly will have to undertake a thorough inspection of the shaft
Some photos cause they are always better.
Yeah the bolt holding on the gear does not appear to have loosened at all, I was able to turn over the camshaft without any problems as well.
Post Posted: Wed Dec 09, 2009 4:18 am
ummm wow.. i have never sceen anything like that b4.... could have been cracekd and just broke ofF?? was it reving hard??
Post Posted: Wed Dec 09, 2009 4:24 am
That look's to me to be the wrong pulley for the cam, or the wrong or damaged key way causing the pulley to spin on the shaft.
I have seen it before.
Did it bend any valve's??
Post Posted: Wed Dec 09, 2009 4:45 am
Hrmm okay thanks for the insight. Pretty sure it was the right camshaft gear as the motors are both 1.3L 1298cc from 95 Sierras, but who know. It is quite possible that the key that holds it in position was damaged and I did not notice when putting the gear on. The motor has run ~5,000k since been put in.
No the pistons did not hit the valves, they don't hit on the 1.3
@jonno_racing: Nah was not revving hard at the time.
Post Posted: Wed Dec 09, 2009 4:51 am
It look's like it was, that's why i asked about the valve's.
Post Posted: Wed Dec 09, 2009 5:07 am
g13a's are free spin.. as in pistons can not hit the valves..
that is strange. i am voteing the pully was fked and had a small crack in it.. and has got worse.
Users browsing this forum: Google [Bot] and 77 guests
