It is currently Sun Nov 15, 2026 5:34 am
Post Posted: Tue Dec 08, 2009 11:26 pm
Hi this maybe covered somewhere else but a mate of mine has a '75 hj80?
and needs to replace the 800cc engine, will a 1.3litre fit?
any suggestions welcome
cheers
Carl
Post Posted: Tue Dec 08, 2009 11:35 pm
Can we clear something up... we are talking about an LJ80 (suzuki) here, not an HJ80 (landcruiser), correct?
If so... Dunno bout a 1.3 but a 1.0 definitely does. Bolts straight up just about.
I want my old sig back :(
Post Posted: Wed Dec 09, 2009 12:25 am
Hi sorry about that yes it is a LJ80.
thanks for the quick reply and i will pass on the infomation
Post Posted: Wed Dec 09, 2009 12:30 am
Yes the 1.0 block/head is the same as the 800cc. You will need to use the 800cc sump and oil pick as the 1.0 sump will hit the steering relay rods.
You will also need the 800cc distrubutor as the 1.0 leans more to the top and the bonnet hits it. It is a straight forward swap. 20% more power! :P
255 characters
Post Posted: Wed Dec 09, 2009 12:38 am
cheers
Carl
Yes a 1.3 will fit, with lot's of cutting & shutting of eng mount's on the chassis.
Worth it in my opinion as parts for 1.3 are more readily available.
Post Posted: Wed Dec 09, 2009 3:37 am
Hutch is correct re fitting a 1 litre. 1300 is a good way to go but a lot more modifications to make it fit, if you go 1300 there are sump to diff clearance problems to overcome as well, also you will need the 1300 gearbox as the belhousings are not the same, gearbox crossmember will have to be cut out and a new one fabricated, gear stick will come out in a different place and interfere with the heater.
Users browsing this forum: No registered users and 70 guests
