| Camshaft Gear came off! http://auszookers.com/forum/viewtopic.php?f=5&t=8518 |
| Author: | Zachius [ Wed Dec 09, 2009 3:54 am ] |
| Post subject: | Camshaft Gear came off! |
Okay so I was driving down to my motorcycle riding test on Sunday (it could have happened some other time - it cost me $161 plus I have to sit the L's test again 2 days off work etc. After opening the bonnet my camshaft timing belt gear had managed to come forward over the bolt that holds it on. The center is all ground out!! What would have caused this? The motor was out of a wreck and in the original accident the camshaft gear was broken. Is it possible that the camshaft was damaged/bent? Has anyone heard of this happening before? |
| Author: | jonno_racing [ Wed Dec 09, 2009 3:56 am ] |
| Post subject: | Re: Camshaft Gear came off! |
was it the gear on the crank or on the cam? |
| Author: | zacs7 [ Wed Dec 09, 2009 3:58 am ] |
Cracked shaft...? |
| Author: | Zachius [ Wed Dec 09, 2009 4:14 am ] |
@jonno_racing: camshaft @zacs7: possibly will have to undertake a thorough inspection of the shaft Some photos cause they are always better. Yeah the bolt holding on the gear does not appear to have loosened at all, I was able to turn over the camshaft without any problems as well. |
| Author: | jonno_racing [ Wed Dec 09, 2009 4:18 am ] |
ummm wow.. i have never sceen anything like that b4.... could have been cracekd and just broke ofF?? was it reving hard?? |
| Author: | steak_knife [ Wed Dec 09, 2009 4:24 am ] |
That look's to me to be the wrong pulley for the cam, or the wrong or damaged key way causing the pulley to spin on the shaft. I have seen it before. Did it bend any valve's?? |
| Author: | Zachius [ Wed Dec 09, 2009 4:45 am ] |
Hrmm okay thanks for the insight. Pretty sure it was the right camshaft gear as the motors are both 1.3L 1298cc from 95 Sierras, but who know. It is quite possible that the key that holds it in position was damaged and I did not notice when putting the gear on. The motor has run ~5,000k since been put in. No the pistons did not hit the valves, they don't hit on the 1.3 @jonno_racing: Nah was not revving hard at the time. |
| Author: | steak_knife [ Wed Dec 09, 2009 4:51 am ] |
Zachius wrote: Hrmm okay thanks for the insight. Pretty sure it was the right camshaft gear as the motors are both 1.3L 1298cc from 95 Sierras, but who know. It is quite possible that the key that holds it in position was damaged and I did not notice when putting the gear on. The motor has run ~5,000k since been put in.
No the pistons did not hit the valves, they don't hit on the 1.3 @jonno_racing: Nah was not revving hard at the time. It look's like it was, that's why i asked about the valve's. |
| Author: | jonno_racing [ Wed Dec 09, 2009 5:07 am ] |
g13a's are free spin.. as in pistons can not hit the valves.. that is strange. i am voteing the pully was fked and had a small crack in it.. and has got worse. |
