It is currently Sat Sep 26, 2026 9:16 am
Post Posted: Fri Dec 11, 2009 2:49 am
I've seen somewhere on the formu that someone sells bushes for zooks. I need set for front and rear. I will do RUF so I need 4 rear ones if there is any difference between front and rear. I,m not sure if it is beter to go for rubber ones or poly. Thx
Chris
Post Posted: Fri Dec 11, 2009 2:58 am
http://www.auszookers.com/index.php?nam ... pic&t=8471
Post Posted: Fri Dec 11, 2009 3:34 am
Front and rear spring bushes are the same.
Rubber flexes better than poly but poly lasts a lot longer than rubber.
Post Posted: Fri Dec 11, 2009 12:27 pm
Rubber flexes better than nolathane but nolathane lasts a lot longer than rubber.
fixed :wink:
poly bushes
Post Posted: Fri Dec 11, 2009 9:06 pm
what hapend there broken spring?
Post Posted: Fri Dec 11, 2009 9:07 pm
no just normal flex, dont all sierras do that :)
Post Posted: Fri Dec 11, 2009 9:39 pm
Ironman sell em, im just about to put a set in mine.
Post Posted: Fri Dec 11, 2009 10:42 pm
ok just dose not look right mate, how much r these bushes?
Post Posted: Sat Dec 12, 2009 3:22 am
thx.
I guess that ironman bushes will be dearer than the one which Bruce sells. How can I find and pm Bruce here on the forum. I can't find username search anymore. What about ARB bushes? Does anyone have used them?
Vehicle: MY2019 Jimny
Post Posted: Sat Dec 12, 2009 3:24 am
Chris, get rubber ones mate, nolathane would limit your flex a bit I reckon.
Post Posted: Sat Dec 12, 2009 3:30 am
lol you lot dont listen do you
urethane is a material, it can be hard enough to hold up a crane or soft enough to squish in your hand (too soft for bushes, I tried)
Bruces bushes are same duro as most rubber ones but stretch MORE so they limit flex LESS than rubber
Post Posted: Sun Dec 13, 2009 3:13 am
I used to think this too, now I'm with Royce
Post Posted: Sun Dec 13, 2009 3:17 am
fixed :wink:
poly bushes
There is SFA flex in those bushes :roll: .. It is all in the twisted leaf spring and the body/chassis is laying over.
Post Posted: Sun Dec 13, 2009 4:20 am
I'll get them from Bruce. Thx for info.
Chris
Post Posted: Sun Dec 13, 2009 12:42 pm
fixed :wink:
poly bushes
yeah the rears didnt twist much cause my springs were so awesome, but you could twist the shackle till it jammed against the tube the bush sits in, so it was metal on metal
Users browsing this forum: No registered users and 56 guests
