It is currently Sun Nov 15, 2026 6:13 pm
Post Posted: Sat Dec 12, 2009 9:25 pm
:cry: so it looks like the tiny coolant leak ive been chasing in my zook with g16b for ages just above driver side engine mount,behind pipe from back of water pump is now visible as a crack in the block(or very very small pinhole at that)
Have been looking for it for a while then today my mate put his little pressure test thingy on the radiator pumped it up a little and found the slightest weep.Has anyone else had similar problems or only really in the head?Also does it sould like its a possible repair :oops:
thanks a heap
Post Posted: Sat Dec 12, 2009 9:49 pm
I have heard of G16 blocks cracking and letting water out...
Whether or not it's repairable would have to be judged on a case by case basis.
Post Posted: Sat Dec 12, 2009 9:58 pm
yep have seen one cracked there before
Post Posted: Sat Dec 12, 2009 11:15 pm
bugger.Damo....any idea on if it was fixed?the leak appears to be very very minor but i guess depends where it is in relation to other parts
is a little bit annoying :cry: hope it can be sorted
Post Posted: Sun Dec 13, 2009 12:34 am
drain the coolant and get a good welder to run a weld over the crack, or stick some chemiweld in the cooling system
Post Posted: Sun Dec 13, 2009 1:37 pm
if there is a chance of getting chemi to take ill give it a go......what have i got to lose i guess.
was talking to my boss last night about it and he reckons going off how small it seems its worth a try as is in the car now to see if he can weld it up.i didnt even think of him,forgot for years that was all he did for a job was weld up cracked heads and blocks.Will see how i go but pretty keen on just trying some chemiweld 1st if people think its worth it?THANKS
Vehicle: Jeep
Post Posted: Sun Dec 13, 2009 9:49 pm
If his specialty is welding up cracked heads and blocks, i would go with the welding, its more permanent/longer lasting, and gives more peace of mind :wink:
Post Posted: Sun Dec 13, 2009 10:03 pm
only use chemi weld if you don't plan on keeping it!
Vehicle: 1993 Suzuki Vitara 4dr Wgn
Post Posted: Mon Dec 14, 2009 12:46 am
thanks a heap
I had something similiar to what you have experienced and a mate in the game put me onto a product called "Seal UP"
Link: Seal UP
He has had customers use it up to 7yrs ago and the engine is still going strong. I've use it in mine some months ago and it has fixed the problem no worries. The only thing is it doesn't mix with Coolant with Glycanol. You have to drain/flush the radiator plenty well then run it for a while, then flush again and then put your coolant back in.... all good.
Or if u use a coolant that uses Organic stuff (ie No Glycanol) then u don't have to worry about the mixing problems.....
Worked a treat for me anyway :wink:
cheers
rob
'93 4Dr Vit, Red Gears,Bighorn 30" MTs, Sliders:B/
Post Posted: Mon Dec 14, 2009 12:51 am
I would weld over anything else nay day, especially if he knows how to do it, otherwise chemiweld might contaminate the crack and the weld wont stick later
otherwise, seal-up is the go
Post Posted: Mon Dec 14, 2009 12:57 am
i used that seal-up on my radiator, haven looked back since
well 2 wekks ago :D hahah is good gear though
Heeyy Haterzzz :lol:
I Love AZ!!! and the controv
Post Posted: Mon Dec 14, 2009 1:20 am
i have had a couple of mechanic mates today say if it is small that chemi should work....or ill look into this sealup stuff.
Am waiting to put it under pressure again so i can see the leak and mark it to show my boss and see his thoughts.Anyone had experience in doing it on the car or only stripped down on the bench?Thanks
also is this seal up really that dodgy of a way?
Post Posted: Mon Dec 14, 2009 1:37 am
Click onto the links and it give u all the data/info....
If $$ is not an issue, then source another motor/block (maybe a Baleno Block) otherwise I personally don't see a problem with Seal UP. What's the worse that can happen... It leak again... anyways it would just mean getting another block/motor so for a little amount of $$ I'm delaying spending a big amount of $$ for who knows how long..... I'm fine with Seal UP :wink: As I said, my mate knows of customers still running around 7yrs later with no problems......
Post Posted: Mon Dec 14, 2009 1:50 am
If you decide to replace the block PM me as I have a G16B bottom end here out of a wrecked Baleno.... Done less than 100 thou K's.
Post Posted: Mon Dec 14, 2009 2:16 am
thanks jas will do.depending on what luck i have with other method/methods i will be in touch.Thankyou
Post Posted: Mon Dec 14, 2009 2:28 am
where have people bought this sealup?
Post Posted: Mon Dec 14, 2009 7:57 pm
I got mine for Hammers Auto on the northside but I think the likes of Burtons Auto or Repco should sell as well
Users browsing this forum: No registered users and 146 guests
