It is currently Sat Nov 14, 2026 11:23 pm
Post Posted: Sun Dec 13, 2009 12:35 am
i bought some new semi sealed lens' for my sierra and have found they dont fit the 'ring thing' that you fit them into before putting them in the car.. what i mean by that is, the lid that the three screws clamp to isn't thick enough. Can you get new 'ring things' to suit or should i try and dodge up the old one? anyone else had drama's fitting new lens'
cheers,
Dave.
Post Posted: Sun Dec 13, 2009 12:38 am
got any pics?
Post Posted: Sun Dec 13, 2009 12:51 am
pics coming in 2 mins. maybe a better explanation is, the outer ring on the lens/insert on the new ones isn't as thick as the old ones...
Post Posted: Sun Dec 13, 2009 12:59 am
Yer Ive seen it before, I had to use spacer's so the light could be clamped in, what ever you use has to heat resistant as the new insert get's very hot.
IMO the seni sealed kit is not wort a pinch of poo, as soon as you go near water with the light's on you will need to replace the bulb's, hot glass & water don't mix.
Post Posted: Sun Dec 13, 2009 1:02 am
use bulbs with real quartz not glass, like phillips :)
Post Posted: Sun Dec 13, 2009 1:13 am
yeah.. i've got phillips +50 bulbs..
pics:
Post Posted: Sun Dec 13, 2009 1:20 am
oh yeah them bits, can you bend them tabs down a bit?
any idea's for a simple spacer fix? might just take to the clamps and bend them a bit more...
Post Posted: Sun Dec 13, 2009 1:26 am
That will do it.
Vehicle: 75 Cruiser
Post Posted: Sun Dec 13, 2009 1:38 am
I put new lights in mine and had the same issue, and just bent the tabs down.
Post Posted: Sun Dec 13, 2009 1:39 am
I had the same problem with mine . I cut some washer bottle hose and used as a spacer.
Post Posted: Sun Dec 13, 2009 3:48 am
I just bent the clamps down onto the light.
TWIN LOCK IT & JUST DRIVE!
Post Posted: Sun Dec 13, 2009 6:39 am
I have used a long piece of vacume line layed around the edge of the light. The fabric covered vac line. It also help prevent the light cracking from the clamp being too tight.
Post Posted: Sun Dec 13, 2009 3:30 pm
got that sorted.. cheers guys.
Vehicle: 95 Sierra Soft top
Post Posted: Mon Dec 14, 2009 1:48 pm
Where did you get the lights from ?? Ebay ??
Post Posted: Sat Dec 19, 2009 5:58 am
hobzees, ebay
Users browsing this forum: No registered users and 81 guests
